Mga tsikoteer ? pls. give idea about my ride honda A/T .
i heard a weird sound na pag natapak ng gas pedal .... seems para nagmumugo sounds like "gluk..gluk ".... but iyon takbo naman no problem and speed. It seems hindi siya ganoon ka smooth ang sound. Do you think it related as ATF or sa engine or sa air intake ?
I know how hard to analyze unless you had heard this in actual. i hope you can help ..
I don't know its the same as ours. Also hear something like that put when depressing the brake pedal in very low speeds like manuevering in tight spots.
mine is when pressing the gas pedal, there is a sound gluk gluk.... when i checked hindi naman sa simota air filter nagagaling. i dont know kung tranny or engine ? .... I hope some of our collegues in tsikot might help us ....
Try to check the ATF baka marumi na by blotter testing on a tssue paper. Drop at least 3 on it then observe if the fluid will spread out and the fluid is in good condition . But if remain small its time to replace and fill fresh fluid. If the problems persist, may ipapakilala ako bumabaklas nyan. Bihira lang kasi sila dahil may special tools and honda:secret:
