Results 1 to 8 of 8
November 22nd, 2006 09:04 AM #1
need your feedback ... baguhan po ako sa mga kotse eh
yung kotse ko kasi kapag after mga 30mins of driving (2nd hand), tumitigas na yung kambyo. tuloy medyo mahirap mag-shift ng gear (up or down). saan po kaya ang problema nito? saan kaya ok magpa-check/ayos nito?
November 22nd, 2006 10:13 AM #2
Ano ba ang clutch niyan, cable or hydraulic?
Nung nagkaganyan kasi yung Benz dati, may vacuum leak pala sa hydraulics ng clutch.
November 22nd, 2006 12:11 PM #3
hindi ko po alam kung ano clutch nito . yung oto ko ay corolla xl 2003.
mas pansin ang problem na ito when shifting from 2nd gear to 1st gear. ang sabi ng isang barkada ko eh dapat before you shift to 1st gear (coming from a higher gear), dapat mag-neutral daw muna. hmmm ... dapat ba talaga? nag-break naman ako before stepping on the clutch (coming from 2nd gear) to ensure na mabagal na ang kotse enough for a 1st gear. no problem ito in the initial 30mins driving ... kapag tumagal na, dapat may force na to shift from 2nd to 1st (pero wala naman tunog).
November 22nd, 2006 12:15 PM #4
ganyan din yung corolla namin dati. hirap magshift to first coming from a higher gear. ginagawa ko rin yung neutral muna before 1st. never found out the reason why though.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 23rd, 2006 11:01 PM #5try replacing the gearoil muna. it's the simplest and cheapest solution.
November 24th, 2006 05:37 PM #6
from any gear to 1st talaga naman dadaan ka sa neutral. gaya ng sabi ni speedy gear oil muna. pede mo rin pa check yun adjustment ng clutch mo.
November 24th, 2006 05:41 PM #7
mahirap kasi kapag from higher gear to 1st kasi kapag di tantsa malakas yung engine break nya.
kapag ako kapag di ko mashift to lower gear, di ko pinipilit. safety na rin un para saken
November 25th, 2006 12:50 PM #8
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
