hehe, talaga lng isaswap mo, sabi ng friend ko mga 8k lng daw po gwin yung conversion kasama na po dun yung manual na tranny, what do you think po if its cheap or expensive
its basically cheaper to convert an A/T to M/T... you just need to buy surplus parts of your car model, you need cable shifter and shift stick, console for M/T, Flywheel, pedal hanger and Manual transmission, just buy brandnew of clutch disc, pressure plates, release and pilot bearing, master and slave clutch plus tubing...
i only recommend this as a last option especially if you are having problems with your A/T but still the best option is to maintain your A/T by replacing it with a surplus A/T which can be bought around 10k to 15k, also it is easier to replace surplus rather that convert.. it also makes your car in its "original" state and therefore maintain its value from manual counterpart
some say po kasi na m/t is fuel efficient compared to a/t and also m/t has more hatak, parang wala po kasi lakas yung a/t palaging ako naiiwan sa highway, if i step on the accelerator too hard at more than 3000 rpm may instances na biglang kakalog yung sasakyan yung tipong parang nageengine brake po, natatakot na po talaga ako sa a/t na to, everytime i use the car hindi nawawala sa isip ko na baka bigla ako tumigil, so i have decided to convert na lang i just need the approval of my father, sir do you a surplus shop that sells m/t of a lancer 93 glxi na mura saka hindi po gano gamit, pwede po ba lagay yung m/t ng lancer el kasi some said that yun daw yung magandang tranny, mga magkano po kaya yung gagastusin, thanks po
yup you buy AT for convinience, not performance. even if madali nga convert from at to mt.. pero i assure you di mo pa nasasama sa costing ang palit ng ECU!
yes MT and AT EFIs have different ECUs.
kaya its more of a hassle nga to convert an efi AT to MT than a carburated AT to MT.
plus pag nakitang converted yan--since di mo naman pinalitan ang dash mo, lalagpak resale value nyan.
so in the end, benta mo nalang yan, palit to MT ka nalang.
