Results 1 to 3 of 3
- Aug 2008
- 38
January 24th, 2012 05:26 PM #1car model is Toyota Corolla gli 94 4afe a/t
Hi guys,
Dinala ko kahapon sa isang motorshop sa congresional ave. yung kotse ko para mag palit ng atf.
Upon inspection, nakita na may tagas/tulo sa gilid ng pan. so pinaayos ko na rin sabay linis ng filter. Nagulat ako bakit 5 liters ang kailangan, kung i di drain lang ito eh 2.5 liters lang para i refill. Since first time ko na malilinis ang filter ng transmission pan/filetr. i assumed na tama iyon. Nakita ko naman na isinalin nila yung 5 liters, paunti unti interval halos eh 15 mins after mabuhos yung 2 liters. binantayan ko eh kaya alam ko na hindi nila binig,la sukat sila ng sukat after 15 mins.
So pag uwi ko ng tanghali ok naman sya wala problem, very smooth ang change ng gears. Kaninang umaga bago ko start yung kotse , check ko yung stick ng atf nagulat ako lagpas lagpas sa marking na HOT. mga 2 inches ang lagpas. Pinunasan ko yung stick then insert ulet, ganun parin, mga 3x ko ginawa pareho talaga.
Overfill ba ang nagyare? may masama ba epekto nito kung lagpas sa sukat ng HOT?? ang COLD kasi eh nasa ibaba ng HOT.
Kailangan ko bang bawasan?
Tia,
Vic
January 24th, 2012 10:20 PM #2
yung marking nasa Hot pag mainit ang manika.
yung marking na Cold kung malamig ang makina(i.e. di pa sya nagagamit lalo na sa umaga).
so kung yung marking e nasa cold during sa umaga, tama lang.
January 24th, 2012 10:28 PM #3
you might have checked the fluid level with the engine off. to check the transaxle fluid;
1- park the vehicle in a relatively level surface
2- run the engine
3- with the engine running shift to all gears while stepping on the brakes at about two second intervals
4- place transmission in park
5- with the engine still running, pull the dipstick and wipe with a lint free cloth
6- reinsert the dipstick in the dipstick tube
7- pull the dipstick and check the fluid level
well, it is common knowledge that our daily ncr driving condition falls under "severe" driving...
Mitsubishi Xforce
