Are they identical when it it comes to parts? I intend to replace the clutch lining, pressure plate and release bearing. My car is an echo 1.3 vvti engine, same as vios. Medyo nagkakaroon ng drag and vibration, although hindi naman sliding clutch. I also suspect na baka transmission support may cause kaya lang hirap silipin kasi natakpan ng base ng battery.
Thanks,speedyfix. Actually, i had it replaced last week and it has the same parts as the 2E transmissions except that it has a different bell housing. Also had the transmission support replaced. Its ok now.
