Results 1 to 14 of 14
    Mga friends, pls help…
    My ride is a corolla xl 1997. Pag po kasi inaapakan ko yung clutch pedal, masi-shift ko pa yung gear, mga 5-10 secs lang ok, tapos maglo-lock na at di mo na ma-shift sa next gear. At this time, parang malambot na yung clutch at di kumakagat. Dahil dun mamamatay na yung makina. Nu kaya solusyon dun?
    Me maisa-suggest ba kayo na good mechanic sa imus area?
    Thanks.
    repair kita ata sira kapag ganito
    May 2007
    yup repair kit lang kailangan nyan.
    Thanks for the reply. Any idea kung how much ang magagastos ko sa mga kits, if i need to buy them?
    May 2007
    check mo muna pala clutch fluid mo baka ubos na.
    please visit this site to learn:
    http://www.ehow.com/how_7677_check-f...paign=yssp_art
    Jan 2008
    Corolla XL, hydraulic clutch ba gamit?
    Di ako sure if its hydraulic... newbie kc eh...
    ^^ i think hindi pa hydraulic ang clutch nung oto. cabled type pa yan.
    May 2007
    kung cable baka pwede pang adjustment lang
    Ang nangyayari po kasi e, if you press on the clutch pedal, it compresses, but loses its compression after a while. say 5 secs of pressing the pedal. Parang me hangin na kumakawala.
    Me mairerecommend ba kayong freelance mechanic sa imus?
    Nov 2007
    Quote Originally Posted by fredzkii View Post
    check mo ang fluid master kung may bawas at kung positive, may leak ang master cylinder or yung slave. Mura lang naman ang repair kit pero before ka bumili ng repair kit check mo muna ang cyclinder kung walang tama kasi yung repair kit will not work or last sa damage cylinder.
    Nov 2003
    if may tagas na yung master or slave replace the assembly. mas matibay than the repair kits.
    from Corolla 1.3 or 1.6 1989 to present hydraulic clutch na yan
    VEry easy to replace the clutch master hirap lang mag bleed nakakangawit
    Corolla 1.3 or 1.6 1989 to 2000 hydraulic clutch na yan
Needs Help... Clutch Problem!!!!
