Results 1 to 7 of 7
    Aug 2003
    is this a clutch plate/pad replacement problem? medyo mahal magpababa ng clutch. or kaya tagas sa clutch cylinders?
    usually this just means your clutch is worn down. In some cars, you can adjust the pedal.
    Pa-adjust ninyo muna ang clutch free play sa iyong suking mekaniko. Mosf of the time ito ang problema. Goodluck. ;)
    kung hindi na ito makuha pa sa adjustment ng clutch pedal probably ay kailangan nang palitan yung clutch assembly. sa mga ganitong instance yung tipong sa sobrang lalim na ng clutch pedal ay nauuna at napapalakas ang tapak sa gas pedal bago umusad ang kotse, kasunod na nito yung "sliding" na tinatawag.
    Sina chieffy kaya magpalit ng clutch. Just bring the parts needed.
    Aug 2003
    BTW there is A LOT of free play in the pedal. about 2" or so. i looked dun sa may ilalim, the clutch pedal is attached to this hydraulic cylinder, and there's about an inch of free play on the cylinder (corresponding to 2" at the pedal) where there is absolutely no resistance. hence my theory of a hydraulic leak..
    Dec 2002
    If the clutch slave cylinder has not been replaced in the last 5 or 6yrs then it may begin to leak without any fluid externally but you'd notice a decrease in fluid in the reservoir. Use a repair kit for slave cylinder, cheap and simple.
sobrang lalim na clutch
