Results 1 to 9 of 9
- Jan 2009
- 163
June 9th, 2012 11:35 AM #1patulong po mga guru, may ride is crosswind xuv 2002 A/T, may problem is bigla di gumana speedometer at odometer ko then nag blink yung check transmission sa panel board,
Ano po kaya ang problema? Normal shifting pa din po ngaun yung sasakayan.
need your advise mga expert.
its happen pala after dumaan me sa baha pero mababaw lang po kinabukasan ng hapaon un na nangyari sa speedometer at odometer ko di na gumana.
Salamat
June 9th, 2012 01:40 PM #2
with the ignition switch off, disconnect the speed sensor from the transmission, dry it up with "dust off" compressed gas used to clean your computer, then apply a light coat of vaseline to the terminals before reconnecting. the shifting is on default mode from a predetermined set of values and is not running at its optimum
- Jan 2009
- 163
June 9th, 2012 02:32 PM #3
June 9th, 2012 02:34 PM #4
- Jan 2009
- 163
June 9th, 2012 02:42 PM #5Sir ayun po ba yung may kasama bolt na 12 ata ang sukat? plastic po yung nakita ko ngaun tama po ba? bale huhugutin then lilinisin ko lang?
dalawa kasi yung nakita ko yung sa kaliwa driver side meron din 3 wire bandang unahan, yung sa kanan meron din 3 wire bandang likod ng transmission.?
cenxa na po sir
June 9th, 2012 07:21 PM #6
- Jan 2009
- 163
June 15th, 2012 10:24 AM #7
June 15th, 2012 10:30 AM #8
That's gotta be in the tranny wirings
Electronic VSS.Last edited by basti08; June 15th, 2012 at 10:59 AM.
- Jan 2009
- 163
June 15th, 2012 11:06 AM #9
have you tried spraying peppermint?
How to get rid of kittens in the engine bay
