Results 1 to 20 of 23
    Looks like our Avanza's auto tranny is dead. Won't move anymore and when they took out the oil - sunog na daw. I am sure there was a reason for it and not wear and tear yon. Haaayyyy anyways, Can anyone recommend a tranny shop - Manila/QC area
    Oct 2011
    sunog na oil? what happened? ilan years na avanza mo?
    TS, ni minsan ba di ka nagpalit ng atf?
    Jan 2012
    Quote Originally Posted by edtf View Post
    hala. what happend sir?
    pano nasunog yung oil?
    Jun 2006
    Get a 2nd opinon. Try to drain and refill your ATF first. You only need around 2 liters of Dexron III ATF.
    What happen exactly? Nabaha ba?
    Sent from my iPad using Tapatalk HD
    Sep 2011
    TS, try mo muna mag full drain ng atf para matangal lahat ang old fluid.
    Nangyari na sa amin yan before, ayaw umarangkada nung starex namin before sa star tollway.
    Yun pala, sunog na ATF and halos wala nang fluid yung tranny.
    Alam ko pinaadjust din yung TPS. Sabi kasi ng KIA mechanic na sumundo sa amin, kasama daw yun.
    ilan taon na iyong avanza ng ts?
    btw, pwede ba panuorin iyong mga sasakyan sa mga toyota casa habang ginagawa/pms?
    oww AT din avanza ko, what happened po and anung condition nung car bago nangyari para maiwasan?tnx
    ^ about viewing, some toyota casas have specially modified their work areas so that you can view them from the waiting area pag pms like toyota north edsa.but for repairs like nung one time na nag palit ako broken window, sa ibang area nila ginawa and di kita.
    Sep 2005
    malamang nalubog sa baha yan sir.. tapos binaklas transmission at nilinis lang.. then after a few months.. kinalawang na yung solenoid assembly.. kaya bumigay yung transmission.. kaya sunog oil..
    Jun 2005
    wala na ba warranty? Try to replace atf muna. kung di kaya, surplus tranny na yan kung may available
    30K kms? so I'm assuming this is the later version, 2010? If I'm not mistaken (better check to verify) yung dip stick ng ATF if (ATF WS), lifetime daw yan, no need to replace, but if yung IV, reco is change every 40K, still dapat covered pa yan. not unless pinang-kakargahan nyo yan or laging ng overloaded at babad sa takbo
    Sep 2005
    kailan yung huling PMS? ilang taon na ba yung oto?
    Aug 2004
    At 30k kms, that's still within most manufacturer's first ATF change interval... though if the car is always in traffic, I'd personally change at 20k.
    Should still be covered by warranty or claimable by warranty if it's just 30k kms, no matter how old.
    Dec 2007
    suggest dalhin sa casa instead and ask toyota what happened. masyado mababa pa ang mileage para masira ang tranny since hindi
    naman nabaha..
    every 5k - around 3years old na. The problem is PMs is done outside of the kasa.
    Jun 2005
    Ano na kaya nangyari sa avanza ni TS?
    Mar 2013
    Sir, tanong ko lang kung naayos pa 'tong avanza mo. nahabol mo pa ba sa warranty?
    Yung avanza ko kasi, around 3 years pa lang din, bumigay na yung auto tranny. sa casa mo na ba sya pinagawa o sa labas? sakin kasi may nakitang mga metal parts sa oil pan nung pina-check ko sa casa. ang recommendation nila, replacement na ng tranny which will cost around P280k. I had to tow it back home kasi di ko kaya yung estimate nila.
    di ba parang masyado naman mahina yung auto tranny ng avanza para masira agad na around 3 years pa lang yung unit? 31k pa nga lang yung mileage ko, di rin naman nabaha.
    Oct 2009
    Quote Originally Posted by Zyvan2013 View Post
    kung ganyan nga kabata ang sasakyan eh mahina nga pagkaka gawa ng tranny niya.280K kaunti nalang idadag sa isang 2ndhand na avanza
    hanap ka nalang siguro ng surplus tranny siguro madami ng surplus niyan.
    Mar 2013
    Quote Originally Posted by jaypee10 View Post
    sana nga maawa pa ang toyota at makuha sa warranty bro,..otherwise, surplus na nga lang,...
ARGH!!!! damaged avanza auto tranny
