also this happened last night, nag maniobra ako kagabi, umatras ako tapos nung aabante na ako, biglang hindi ko ma-shift yung shift stick, as in stuck sya, pero nakatapak ako sa clutch. hmmm..... then after a few minutes naikambyo ko din.
right now okay na naman clutch ko, except for the pedal na lumalim.
as a temporary solution lang, paki post naman step-by-step adjustment ng clutch pedal, by the way the car is Lancer GLXi 97.
it might not be as simple as adjusting the clutch. baka sira na master mo kaya no more fluid can flow. in any case there should be a screw behind the clutch pedal which can be adjusted to move the play earlier or later
try checking fluid level sa clutch reservoir mo... baka low na. if it is, meron kang leak somewhere that causes ur clutch fluid to get low... thus having difficulty in shifting
loosen the bleed screw (located sa side ng lower master), pump the pedal. have someone add fluid until the fluid coming out of the bleed screw is clear. close the bleed screw. have someone pump the pedal and top up the fluid. open the bleed screw to let air out. do this 2 times until a steady flow of fluid squirks from the screw.
Since wala kaming makitang leak whatsoever, and after bleeding the clutch eh ganun pa din we decided to replace the clutch master kit and ngayon eh okay na.
