Results 1 to 10 of 20
May 1st, 2015 09:37 PM #1
something odd happening in my sedan MT is not smooth shifting. Checked & observed the ff
1. no leaking
2. replaced the fluids already 5 months ago
3. no burning smell
4. no gears slipping but sometimes, it's difficult to shift into reverse gear.
what do you think is the cause of a problem or defect??
- Sep 2008
- 596
May 1st, 2015 09:43 PM #2Most likely a clutch problem, what is your mileage? It could be either the clutch slave or the clutch disc/pressure plate
May 1st, 2015 09:49 PM #3
^^ 41k mileage. at saka pansin ko medyo stiff na rin ang clutch pero manageable pa naman. never pa naibaba ang clutch nito..
- Sep 2008
- 596
May 1st, 2015 10:00 PM #4your mileage is so small para maging clutch disc/pressure plate problem unless you are a clutch driver or something extraordinary is wrong with it. I would rule it out, so I would like to think it is a clutch slave issue. Baka naman all it needs is a little adjustment sa clutch lever to make shifting smoother. Mababa ba ang clutch?
May 1st, 2015 10:06 PM #5
shifter bushing, baka pudpud na. it is made of plastic. around 50 petot/pc yata. usually palitan mo 8 pcs. just have it check pag medyo sumasabit. madalai lang ikabit po yan sir. you can even have it DIY, kung yon nga ang culprit.
May 1st, 2015 10:07 PM #6
di naman mababa or mataas kundi nasa gitna lang. di pa ito na-adjust or nagalaw since nabili ito ng brandnew
nope di talaga ako clutch driver. kung minsan nga nanginginig na ang makina saka ko pa lang press ang clutch pero bihirang bihira lang ito mangyari. hehe
- Sep 2008
- 596
May 1st, 2015 10:11 PM #7if you are sure na walang leakage including where the clutch slave is located, you might need to check the internals ng clutch slave, baka ang rubber cups ay malambot na. There is a repair kit for that
May 1st, 2015 10:14 PM #8
shifter bushing? saan ko kaya makikita ito sa pang-ilalim o sa loob rubber boots ng kambio? nasa youtube DIY ba to? TIA
May 1st, 2015 10:20 PM #9
yup talagang walang leak. kapag umaalis ako sa parking ko i check yung floor kung may tagas na any fluids. tubig lang galing sa a/c
- Nov 2009
- 456
May 1st, 2015 10:30 PM #10
Cons, masarap sa mga daga.
BYD Philippines
