Results 1 to 7 of 7
    May 2004
    Hey guys need your help
    I have recently experience na parang nag-stick iyun clutch ko pag nasa 1st and reverse gear ako (ayaw matanggal sa 1st gear while moving until mamatay iyung makina, then saka pa lang ma-release). I have cleaned and replaced (repair kit) iyun secondary master dahil merong mga bakas ng leak but this had not solve the problem. Ano kaya ang problem, I cannot use the car dahil laging stock-up sa 1st and reverse gear.
    TIA!
    Jul 2003
    since na-repair na yung secondary master, chack mo na din yung clutch master. ganito yung problema ko ngayong week lang na ito. OK na kotse ko.
    kung ganun pa din, baka sa transmission na problema.
    Oct 2005
    pressure plate na yan, due for replacement. some various tranny parts pa.
    Happened that to my rolla and Adventure before. In the meantime, wag ka maging clutch driver para di dumali ang buhay ng clutch mo.
    Lagi ka mag neutral while waiting for the go signal even sa 'hanging' na tinatawag.
    Dont do clutching sa humps, when turning etc.
    May 2004
    Quote Originally Posted by fourtheboys96 View Post
    this is my plan right now to also check iyun clutch master, hope na narito nga sana ang problem
    *V6dreamer
    sir what do you mean na "dont pump the clutch pedal" when bleeding, what is the proper procedure to do the bleeding?
    May 2007
    Quote Originally Posted by tholitz View Post
    *V6dreamer
    "PUMP" do not push the pedal simultaneously. If you have an helper tell your helper to push and hold, release the clutch only in your command, again do not let your helper pump. When you done bleeding your clutch you may have to purge the slave cylinder of any bubbles that might be trap inside of it.
    May 2007
    TIA!
    Did you bleed that clutch as you have done repair on the master? If not, then you must. One thing to remember when bleeding a hydraulic clutch " do not pump the clutch pedal". Do the proper procerdure to avoid damage. If all fails, then you have a bad pressure plate and throwout bearing.
    Oct 2007
    Bro, After mo ma bleed ang clucth mo, medyo critical ang pag bleed ng clucth kay sa preno but I see thread in here na nag sasabi ng proper way to bleed ng clucth, ganyan din kasi ang nang yari sa akin, 3day yata ang inabot ko bago ko na ayos, may kasama pa ako pag nag bleed kala ko kaya ko ng 1 araw pero hindi ako pinalad, at naalala ko sablay din pala ang una kung nabili na repair kit ang mahal panaman syempre gusto natin magandang klase ang kabit natin sa wheels natin pero hindi din pala ubra ang mahal lang da best pa din recommended yon bili ulit ako, bago pa nag ok, well napa haba ang kuwento ko hindi ko kasi malimut yon, but any way, after mo ma bleed check mo kung nag pi-play ang hydrulic clucth mo kapag ina-apakan dapat may presure at pag release ng pedal ay babalik din ang secondary push rod try several times.........
ayaw mag-release ng clutch
