Results 1 to 8 of 8
    Aug 2013
    Good day mga sir. Gusto ko lang iclarify kung sa tranny nanggagaling yung whining sounds ng CRV 02 namin. Nagpareplace kasi ako ng surplus tranny tapos napansin ko na may whining sound kapag nakatigil kapag nasa park or neutral. Tapos bumabalik balik yung tunog kahit umaandar na. Smooth naman yung tranny no jerks and delays etc. Tapos ok naman yung atf level at bago pa.
    Sa tranny ba to mga sir? Sabi kasi baka daw sa power steering pero puno pa yung power steering ko eh. Nakakakaba tagal ko na kasi pinroblema tog tranny ko.
    Salamat sa magrereply!
    Feb 2009
    Quote Originally Posted by bogsingbagsik View Post
    fact
    you are not sure whether it is the hydraulic power steering or the transaxle is the source of the noise.
    to eliminate the possibility of the hydraulic p/s as the source of the noise, temporarily remove the p/s belt and replicate the driving conditions when the noise usually occur. if the noise is still present with the p/s belt off, then it is your transaxle
    Oct 2009
    manual ba or matic ang tranny.dati bang wala ung sound na yan bago mo papalitan ng tranny
    Feb 2009
    is it alltrac or awd?
    Aug 2013
    Thanks sa reply mga sir!
    Matic 2-WD pala to boss. Actually 2nd palit na to, kasi yung unang sinalpak 5-speed kaya nagkaproblema sa sensor. Wala ako napansin na ingay dun sa una. Ngayong tama na yung tranny na ginamit, dun na ko may napansin. Wala din ingay dati prior to any tranny replacement
    Could it be something sa mga belt? Pansin ko kasi na nagiiba yung pitch depende sa RPM kapag nirerev ko in park/neutral. Nagtataka lang ako na nawawala siya minsan while moving pero just for a few seconds
    Aug 2013
    Eto siya mga boss: Whining - YouTube
    Sana talaga sa PS lang may issue
Whining Tranny?
