Results 1 to 11 of 11
    Feb 2004
    Changed the clutch plate, release bearing and pressure plate (AISIN), mahirap pa rin ipasok sa primera o atras yung kambyo pag uminit na (driving from QC to malolos, about 50-60kms). Ano kaya cause nito at paano to maayos? Bagong palit na rin yung transmission fluid.
    Gaano ba katagal ang itinatagal ng pressure plate (OEM) vs Replacement?
    Quote Originally Posted by xfreemanx View Post
    What's your ride? Mine is 1992 L200 pick up. Old na. Hirap din magshift lalo na sa first gear. What I do is to go first to fifth gear then back to firstgear. Parang nagparinig yung mekaniko na palitan na ang buong transmission...
    Nov 2007
    [quote=xfreemanx;1174586]Changed the clutch plate, release bearing and pressure plate (AISIN), mahirap pa rin ipasok sa primera o atras yung kambyo pag uminit na (driving from QC to malolos, about 50-60kms). Ano kaya cause nito at paano to maayos? Bagong palit na rin yung transmission fluid
    I suggest have your clutch system adjusted and use the recommended fluid based on the owner's manual....good luck.
    Oct 2008
    tama adjust po muna yung clutch freeplay nya baka dun po makuha na po
    Nov 2007
    sa tingin ko clutch disc sunod clutch master and secondary, check nyo na din ang cable
    Jan 2008
    try adjusting the clutch pedal first.. dapat hindi tukod and adjustment and dapat yung pag tapak mo ng todo sapat lang para pumasok ang 1st gear... you can shift the gears as soon as the pressure plate disengages the clutch disc kaya no need to push it to the maximum range of the pedal..
    in common terms dapat yung clutch adjustment mo eh MABABAW lang yung tipong pag tapak mo pasok ng 1st gear dapat konting release lang eh kagat na agad ang clutch..
    also possible cause is yung clutch master and slave mo need to replace na.. pag umiinit na yung fluid nag expand na causing your clutch to stuck-up..
    worst case is sira na yung synchronizer mo kaya hirap na pumasok sa 1st and reverse
    Jul 2006
    Completely agree. Check easy ones muna, like fluid level or adjustment.
M/T: Mahirap ipasok sa primera at atras pag uminit na
