Results 1 to 8 of 8
- Sep 2013
- 630
October 29th, 2013 12:41 PM #1Honda automatic transmission no real filter. Only screen.
Available locally?
- Sep 2013
- 630
November 11th, 2013 04:01 PM #3Wala ata available locally.
Maghahanap daw ako filter head surplus.
Pero kung wala talaga order na lang online.
November 24th, 2013 10:00 AM #4
Finally installed the DIY inline ATF filter of my Corolla GLi BaBy last friday. Used a Korean made fuel pump filter head with M20 x 1.5 thread, nahingi ko sa car repair shop near my place. Bought a filter that matched the gasket face ng filter head, B173-S Baldwin spin on lube filter, 2 pcs - 5/16" x 36" rubber fuel hose, 2 pcs - hose clamps and 2 pcs - mounting bolts, 3/8" x 1".
Installed the filter sa harap ng aircon condenser, katapat ng radiator fan where I have space for changing the filter, madudukot sa ilalim ng bumper, no need to remove the front grill. Maluwag naman ang hose route, from radiator fluid cooler outlet to filter inlet at filter outlet to tranny fluid sump inlet, just added half a liter ATF that increases the quantity to almost 8 liters and it also helps cool down the fluid temp kasi nadadaanan ang filter ng cold air sucked by the radiator fan. All in, nagastos ko ay almost Php500 lang, ang return naman ay healthy tranny at extended FCI from regular 30k to maybe 45k kms.
Looking through the front grill, the filter head and Baldwin filter
Looking on top, filter head with pump is below the horn
- Jun 2006
- 1,139
November 24th, 2013 12:06 PM #5Di ba bumaba ang oil pressure? I also have a lovelife that the tranny is starting to have problems in reverese.
November 24th, 2013 06:07 PM #6
I just inserted the spin on full flow filter sa ATF return hose from oil cooler to tranny sump. I don't think it will alter the fluid pressure, sa loob ng tranny yata located ang pump that circulate the fluid.
For your tranny, I recommend you fully replace the ATF kung dirty na din lang, baka dahilan ng shifting problem sa reverse. DIY full replacement is very easy.
- Sep 2013
- 630
November 25th, 2013 04:24 PM #7Inggit ako ah. Maghahanap din ako para sa FD at City. Hanapan ko space saan maganda ipuwesto.
Sa banawe ba yan talyer nakakuha ka filter head? Tamang tama yung 20x1.5 thread sa mga honda. Pero yung gasket baka hindi magmatch sa B1431 or B161-S.
December 2nd, 2013 02:55 PM #8
Before you buy a spin on lube filter, hanap ka muna filter head, sa Banawe, sa area ng Kaliraya, doon marami. Kahit wala na primer pump, hanapin mo full flow filter head na outside going inside ang flow, iyon ang direction of flow ng mga lube filters we buy. Pwede din kahit different thread size, 3/4"-16, etc.
VinFast VF 3
