Results 1 to 10 of 21
November 7th, 2006 09:07 AM #1
Meron ba alam ba ang specs na para sa MTF ng honda 96 civic, plan ko kasi to change oil, and sa manual sabi Use Genuine honda MTF, any good alternative to use, brand or specs?
November 7th, 2006 09:14 AM #2
M/T po ba? sa Honda lang meron nyan pero pwede na ang mineral base engine oil dyan.
November 7th, 2006 09:25 AM #3
November 7th, 2006 01:07 PM #5
check your manual, meron din po dun specs. sa pagkakaalam ko kasi wala naman pong processing plant ang honda, toyota or nissan or mitsu ng fluids, lubricants, oil and grease. kaya they just partner with local lube dealer lang.
example:
personal computer / laptop etc...
brand is HP, processor is intel, board is asus (alhough di ko alam pero most likely intel din)
building / infrastructure
designer is Designer 1
installer is different
honda car
engine designed by honda
shocks, spring, suspension though designed by honda but get from a specs based on standard manufactured items.
such as spark plugs
di po ganon ka extensive ung knowledge ko sa car pero pagkakaalam ko lang po ganun, kaya sa manual may nakalagay n generic dun n parang sa gamot. akin 97 vti, matic, pero ang ginamit ko n fluid is ung sa petron lang po, kasi dexron III compliant n po iyon. and very much compatible with dexron II.
hope nakatulong ako...
eng
November 7th, 2006 01:13 PM #6
bro look it up in the thread i made several weeks ago. we faced the same dilemma and it was discussed extensively there and it helped me a lot. ngayon swabeng swabe ang gear shifting ko sa ek ko
November 7th, 2006 01:15 PM #7
wala kasi akong makitang specs for manual transmission fluid, kahit sa manual na na download ko sa internet wala ring specs ang sabi lang Genuine honda transmission fluid.
November 7th, 2006 01:25 PM #8
Nagpalit ako last time. Castrol mineral base oil lang pinalagay ko. Ok naman. Ikaw lang ba ang magpapalit(DIY)? or dadalin mo sa shop?
November 7th, 2006 01:35 PM #9
...err, stupid question. when you say M/T fluid, pareho lang yan pag sinabing nagpapalet ka ng gear oil?
November 7th, 2006 01:38 PM #10
Be careful with channels like "China Observer" on YouTube. There is a clear bias in their posts and...
Xiaomi E-Car
