Results 1 to 5 of 5
    Jul 2010
    My 1992 L200 pickup is exhibiting some weird behavior in its transmission lately. It has already 350T km in its odometer and never been overhauled.
    The master and slave assemblies had been replaced with new ones.
    When the traffic is heavy and I have to shift rapidly from time to time, I find the transmission unable to shift.
    As I turned off then turned on the engine, I noticed that I could normally shift again.
    When the traffic is light, there is no problem.
    What could be the cause of this problem?
    WEre you able to change the gear oil na? Kasi pag ganyan medyo maganit na sa loob. BTW were you also able to change the clutch disk and all of its accompanying components?
    Check also your clutch fluid it may be low level. Changing your Transmission gear oil may help in shifting smoothly.
    Jul 2010
    thanks to Maz and Speed.
    I will post the result after I have done the suggestions.
    Apr 2009
    bro ganyan din sa litace ko ngayon, kapag mahigit isang oras na umaandar mahirap na ipasok ang kambyo kahit bombahin ang clutch
    dalawang mekaniko na ang may sabi sakin na palitan ang lining, may brand daw na ganyan kapag mainit na mainit na
erratic manual transmission
