Results 1 to 9 of 9
    Hi. I was told by the mechanic that I need to replace all four transmission support for my 96 corolla gli. He showed me a rubber below the air filter that was cracked. He said that the 3 others are also cracked. Was I looking at the proper part?
    I am having trouble deciding on whether to get original or replacement. The estimate to have the four supports (original) replaced was P10,800 for the parts only. I want to know how critical the transmission support is in my car's good performance (like will it cause me to stall if it gets severely damaged?).
    Depende. If madaling palitan, I would go for replacement parts. If magtatagal yun car sa iyo, original parts. Di ka ma stall but you'll have vibrations/backlash/noise that you've never experience with good supports.
    Jul 2006
    Just from experience and what I've read, replacement parts can go bad sooner than original/OEM parts.
    Afrasay has a good point, if you plan to keep it use good quality materials/OEM/"original" items. Peace of mind mo na rin yon. Can't really put a price on that di ba?
    Go for OEM. Mashadong malambot yung ibang replacement parts. Halos walang difference.
    kung talagang kulang ang budget para mag-OEM, mag-japan replacement ka na lang.
    ang brand name nito sa auto supply shops ay JAC, meron silang catalogue for various japanese cars.
    ito ang kinabit ko sa lancer ko after a general overhaul two years ago. tahimik naman, walang vibrations din.
    May 2004
    japan replacement if tight budget. else, go oem.
    I'll go for OEM na lang. My engine is due for overhaul na din. Thanks
    Sep 2004
    Mahal naman ng OEM. I just buy good jap replacement like JAC, etc.
    Tatagal din naman.
    Nov 2003
    most jap replacement supports i see are good enough.
Transmission Support: Original or Replacement (Japan)
