Nissan Serena QRV.R Ltd. A/T 2002
1. Sometimes when running on a not-so-heavy load, the car feels really heavy and medyo hirap ang engine. I would need to press the gas even harder to go faster. There are times na with a certain amount of load, magaan ang car. A little press lang, hataw na kaagad. But sometimes with the same load, mabigat ang feel. Sa transmission kaya 'to? or is there such thing as pagod or stressed ang car?
2. Do A/T/s have some anti-slip thing? Kanina I parked on an uphill road. I parked on the side of the road and on a wet bermuda grass area. So madulas nga sya. Then when i was about to go na, I shifted to 1, then when i pressed the gas, parang it was hesitating to go even if i was pressing half-way. Was it trying to avoid a slip? It did start to move uphill on the slippery part but it was slow. Then when it got to cement where theres traction, biglaan na lang tumakbo. It's normal right?
3. Re: no.2. Is it bad to do that? parang forcing the transmission to negotiate the slippery surface and just move forward. Should i have just reversed to a road with more traction. I did feel a backward-forward vibration on the car while it was trying to climb.
engine: no bad signs in itself. no weird noises. revs smoothly and willingly.
