Results 1 to 11 of 11
    Mga sir help naman po kapag nag si shift po ako from second to third gear e my sound na parang bumabagsak na bakal o nagkakatamaan na bakal..pero from fourth to third gear naman e walang problema tahimik naman..anu po kaya problem nung clunking sound na yun..salamat po
    Strada 2008
    Jan 2014
    Sa akin naman pag biglang release ang clutch sa 1st and 2nd gear meron akong marinig na "bog" sound,pero kung releasing the clutch slowly wla akong marinig. i went to mitsu davao and tagum.they drove and checked my strada(2013 4x4)but according to them its normal since meron clearnce ang differential na up to 5cm ,mine is only 2.4cm(differential backlash).
    Quote Originally Posted by mosso670 View Post
    yan ang talagang nakakatawa; differential backlash 2.4 cm and limit 5 cm he he alam ba nila pinagsasabi nila?
    Feb 2009
    Quote Originally Posted by rdz03 View Post
    Strada 2008
    Anong khotcheh ser. Anong mileage? Front wheel drive o rear wheel drive?
    Dec 2014
    Kung iisipin natin, siguro tumatawa si Supreme Court Associate Marvic Leonen sa tuwa na nakaligtas siya sa backlash arising from this incident. He was actually the chief negotiator for the GRP. Right after the signing of the War (err) Agreement, he was appointed as justice by Abnoy. Ngayon si Coronel-Ferrer along with Deles tuloy ang nayayari.
    Jun 2005
    Quote Originally Posted by machine.pistol View Post
    huh? pati ba naman ingay sa transmission kasalanan pa din ni abnoy?
    Quote Originally Posted by sirkosero View Post
    dito ako natawa
    Jun 2015
    un skin nman sir primera pag nirelease mo un paa mo sa clutch at nag bigay ka ng gas my humming sound ako n nririnig lalo na pag paahon anu kyang problema nun mga sir?
    ?what's that?
    Apr 2015
    Strada 2008
    Sir kung strada yan, rear wheel drive. Kung pag biglang release ng clutch parang may kumakalantog na mga bote sa ilalim, cross joint yan ng propeller shaft mo. Loose na. Hence the clunking sound. Try to replace it na lang.cheers!
    Jun 2015
    gud am mga sir.. help nman po my naririning po akong humming sound sa m/t ng kotse ko pag palusong. prang hndi normal e . anu po kya un sanhi nun?
help m/t clunking sounds
