Results 1 to 20 of 41
    Apr 2006
    hi guys -
    just want to ask. what i do during stop-and-go traffic when i want the car to move just a few meters/feet is to bring the clutch to it's working level without applying gas. when i want to stop, i just press on the clutch and the break. is this a good or bad practice? should i use the usual way of applying a little gas to move? is this fuel-saving?
    thanks.
    actually, walang problema dun, as long as di mo ibababad. put it in neutral kung nakahinto ka na...
    Sep 2006
    oo ok lang yung. basta din wag mong hayaang mag-engine knock.
    Wala naman wear sa clutch when it is fully depressed. Wear occurs as you transition from fully depressed to fully engaged.
    Aug 2006
    makisakay na din..
    ok lang ba na before reaching the traffic, switch na to neutral ang kambyo? ganun kasi ang ginagawa ko, esp during stop light...ano kaya effect nun?
    Sep 2006
    pag walang engine brake, cyempre more effort yung brakes..
    Quote Originally Posted by buraot View Post
    makisakay na din..
    Yun din ang ginagawa ko. Normal naman palit ko ng brakes. Naglast naman ang tranny ko. 169k na odo ko. Although, nagpalit ako ng gears ng 120k (2nd gear).
    makisakay na din..
    ako din ganyan, kapag malapit na neutral + feet off the gas and clutch then glide while gradual braking (yun sobrang hina) para sakto lang hinto sa traffic
    Quote Originally Posted by wewoy_romero View Post
    hi guys -
    thanks.
    yan din lagi ko ginagawa!
    ang alam ko ok lang ung ganun basta wag lang mag bababad ng hafl clutch!
    fine and good as long as gradual ang release ng clutch and
    no excessive vibrations occur. remember mas mahal ang engine
    repair compared to drops of fuel.
    Quote Originally Posted by sirmykel View Post
    tanong po, anu po ung engine break?
    while braking, engaged ka pa rin sa huling gear mo
    bago mo i-neutral.
using the clutch in stop-go traffic
