Results 1 to 10 of 11
October 20th, 2008 12:06 PM #1
ano po ang cause ng hard shifting(sticky shift stick) if cold start pa po?
matigas talagas from neutral to 1st gear.
October 20th, 2008 12:11 PM #2
anu clutch mo - cable type or fluid? baka kailangan lang ng konting grasa(pag cable) or palit fluid(or hose).
have you checked yung gear oil level baka mababa na din...or matigas na talaga yung clutch.
check mo din linkages or cables ng shifter baka need greasing na din.
so far un lang naiisip ko..
- Jan 2008
- 4,726
October 21st, 2008 07:31 PM #5san ba matigas 1st gear lang??? possible kasi na yung cable shifter mo due for replacement na... also possible na mali adjustment ng clutch pedal mo...
dapat may play yan hindi dapat tukod at yung adjustment ng tapak mo dapat mababaw lang.. sakto lang pag full press mo papasok yung kambyo at pag release mo konti bitaw lang kapit agad ang clutch...
October 21st, 2008 08:23 PM #6
October 22nd, 2008 10:24 AM #8
October 22nd, 2008 10:53 AM #10
adjust clutch freeplay po.. sa push rod ng master or sa slave cylinder or pag cable dun sa may clutch fork nya tnx
VinFast VF 3
