Results 1 to 11 of 11
    bigla kasing na drain yung battery ko kanina. eh no choice kundi itulak ng mga mmda sa tabi. ano po ba ang pwedeng masira sa kotse pag tinulak? nilagay ko lang sa N ang gear nung tinulak. please advise. thanks!
    pag naka N walang problema.
    kung tinulak lang para itabi ok lang yan... wala pa namang harm na magagawa yan.. ang masama is to tow it with the driving wheels down (even if its in neutral)...
    pwede ba kadyot ang at?
    kadyot? as in parang push starting the car?
    meron sa manual nung accord namin.. parang you have to reach a certain rolling level or something... ewan.. nde ko pinapansin.. basta may jumper cable lang ako sa trunk.e hehe
    Jan 2003
    Quote Originally Posted by HBOY
    bakit masama? sorry, di ko lam eh... :oops:
    As the others mentioned, basta neutral OK lang itulak.
    Namatayan din yung bro ko sa gitna ng Ayala Ave the other day. Buti lang at nakasunod ako at mabilis ko na-switch and batteries para i-start yung kotse or else mapapatow kami niyan.
    It works best if you always keep jumper cables and a tow rope handy para mabilis ma mobilize yung car should the battery die down. Just make sure that you get a jumper cable with at least a 200amp rating. Based on experience, the 100amp ones cant carry enough juice to start another car.
    Ba't masama i-tow on the driving wheels? It puts stress on the drivetrain axles and suspension... CMMIW.
    Sana ma-educate din mga towing companies & MMDA na pag A/T, masama i-tow.:x
    you can tow a matic car.. as long as teh drive wheels are lifted from the ground... or better yet.. if you get car trouble.. and you called a towing service.. ask for a flatbed truck.
    anung mangyayari..
    dati un kinakatok un volvo 940SE namin.. de hila ng van... naka N.. pero ayus na now.. anu ba mga mangyayari?
    nde umaandar ang makina?? no ATF fluid going around your slushbox... meaning no lubrication on the gears, the planetary gearset (sobrang mahal nito pag ito ang nasira)... nde naman biglaang masisira... but the wear and tear on your tranny will be greater than if its not being towed.
consequences ng a/t na tinulak
