Good evening.
Had replaced my A/T's oil seal twice in 6 months and it cost me a lot. Is there a way I can have this fixed without replacing entire transmission system. But if worse comes to worst, please advise if you know someone expert on Automatic transmissions and how much if i buy a new or at least a 2nd hand tranny.
the seal lip with vaseline to prevent the seal from burning during the first few turns of the shaft. the other sources of leak would be at the speed sensor, the odometer drive gear, at the dipstick tube o-ring and at the oilpan gasket. on the rotating parts that use the lip type seal, inspect the seal race for wear or nicks. if you use the wrong transmission oil it will also cause some leaks as the types of atf are formulated different. if the problem is just a simple leak and the shift timing and pattern are normal, just take care of the simple oil seal. slight seepage is normal part that provides lubrication for the seal. another point is to check that the transmission breather is free and not clogged, the transmission should not have excessive internal pressure or the oil will go past the seals which were not designed for pressure. good luck with the repairs
