Results 1 to 10 of 10
    mga sir,
    question lang po, ano po kaya ang cause, ng ayaw pumasok ng kambyo? o hirap? minsan nakaka 2 to 3 tapak ako sa clutch bago pumasok? usually sa 1st ,2nd and reverse gear lang po nangyayari..
    btw, my ride is a 94 glxi lancer..thank you
    maybe you need to replace your clutch system.
    or worst that could be a synchronizer problem.
    Try first to have your transmission fluid replaced sa iyong suking gas station. Observe for a few days kung ganun pa din.
    Kung ganun pa din even after a tranny fluid change, have your clutch system and your tranny checked.
    synchronizer key and synchronizer gear sa 1st/2nd gear train.
    sa reverse baka adjustment ng linkage kasi mahaba ang throw nyan.
    Kung hydraulic clutch, you could try to have it bled and adjusted. :D
    maraming salamat sir sa mga replies...mukhang sa clutch master ang problema...
    my friend has the same problem in his lancer...
    Jan 1970
    Pahabol lang mga sir.... when do we have to change the transmission oil??? every 5,000km po ba or every 3,000km????
    At anong magandang transmission oil na bagay sa 95 Toyota Corolla???
    Salamat po....
    tranny oil around every 30K I think.
    jolam,
    its usually aroung the 20-40K mark, kung me manual ka pa check it...iba-iba recomendation depending on car brand....pati na rin ang rate of use (abuse)...pedeng mas shorter and period ng change
    Originally posted by wildthing
    jolam,
    :aprub: well said wildthing :cool:
difficulties in shifting
