Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Feb 2013
    HELLO,mga katsikots magtanung uli ako sa inyo kung normal ba sa automatic transmission na pag nakapark ka sa medyo inclined o matarik tapos pag abante ka sa drive na hindi mo masyado diin selenyador o parang alalay lang ay aatras pa yung sasakyan ko bago aabante.akala ko kasi pag naka D ka ay hindi aatras.minsan kasi may nakatutuk sa likod ko noong nakapark kami sa inclined na kalsada nang aabantre ako ay muntik mabunggo cya buti nadiinan ko agad selenyador kaya yun umabante agad.mga 30degrees inclined yung kalsada nagparkan namin.salamat sa inputs.
    dapat hindi,
    habang apak mo ang preno and ilagay mo sa D, walang galaw dapat yan.
    Ganyan sa vios ko pag masyado matarik. Kaya brake muna bago tanggal sa park then quickly switch your foot to gas.
    Posted via Tsikot Mobile App
    Jan 2009
    With most conventional A/T, there's a slight lag from the time you shifted to Drive and the gears/torque converter engaging. Keep your foot on the brakes until you feel the car starting to lurch forward.
    On a very steep incline with the engine at idle, it may not have enough power to keep the car from rolling backwards. In this case, you have two options to keep the car from rolling backwards:
    1. Use the brakes as a pseudo clutch. With your left foot firmly on the brakes, apply some gas with your right while releasing the brakes slowly. Remember to do this very gently to prevent the car from surging forward
    2. Use the handbrake method as you would in a manual transmission
    Jun 2013
    yes, hand break
    Aug 2004
    Quote Originally Posted by Erick Chavez View Post
    yes, hand break
    It's spelled BRAKE.
    Feb 2009
    If the idle speed is too low or the engine is misfiring there is a tendency for a car with A/T to roll backwards when going uphill from standing still even in D range
    Nakiki wi-fi lang
    Aug 2012
    kahit naman sa M/T if matarik ang daan.. aatras ang sasakyan if galing sa hinto at kulang tapak sa gas. matarik na yang 30 degree..
    Quote Originally Posted by red_one View Post
    Lalo na s pg mga medyo newbies s pgddrive tpos manual gmit, nakupo atras tlga un hehe
    Jan 2013
    gravity
    Oct 2011
    Quote Originally Posted by glxexurb View Post
    gaano ka tarik ba yan sir? isang beses ko lang na encounter yan nung nag atras sa may basement parking ng jackman plaza.
    yung Sentra ko na A/T, even sa mga flyovers hindi naman nangyayari yang ganyan. its a timing on the release of the brake/handbrake.
    may onting onti lang pag paakyat ng basement parking.
    Aug 2012
    Quote Originally Posted by 1D4LV View Post
    that's what we are saying here. normal lang na may konting atras due to Gravity. you should help the car climb up by pressing the Gas pedal. same thing lang with M/T.. aatras ang car if di mo tapakan ang Gas.
    Jul 2011
    Sa tingin ko ang expectation ni TS sa mga AT pag naka D kahit walang tapak ng gas e hindi aatras ung car.
    AT ang gamit ko at pag inclined umaatras talaga kahit naka D, pero kung gaano kalayo ang iaatras hindi ko na sinubukan.
    Unlike sa mga MT na pag naka gear at asa inclined ka pag bitaw mo ng clutch at walang gas, e mamatay ang makina pero hindi ka aatras.
    Aug 2004
    Some cars have something called Hill Start Assist. When it detects that the vehicle is stopped on an incline it will automatically apply the e-brake for a few seconds after releasing the brake so it doesn't roll backwards or forwards. It's also available on AT cars. So even the manufacturers think it's normal.
    http://en.wikipedia.org/wiki/Hill-holder
    Aug 2012
    tama nga naman. but if nakatapak ang clutch, uurong ang M/T sa inclined. gears are not engaged.
    Oct 2011
    Quote Originally Posted by Manilablock View Post
    hindi ba yan depende sa steep ng incline sir? sa mga bridge or flyover especially during heavy traffic hindi ko naman na encounter ang pag atras when shift to 'D' without depressing the gas pedal.
    Jan 2004
    experienced it also sa AT car ko, sa mga inclined ramp ng parking and if car is loaded
    Jul 2011
    Yup! depende sa incline, pero hindi mo dapat iasa sa D ung car mo na hindi na aatras, it is still best to step on the brakes or mag hand brake.
    Aug 2004
    Do not let your AT car hang on an incline by just using the gas pedal. You'll burn out your ATF and clutches.
At-may konting atras muna bago abante
