Results 1 to 10 of 10
    Apr 2005
    Please help,my innova D4D A/T had hesitation on D gear when came from stop.Also had the same in 2 and 3 gear.Kapag umangat na from stop wala na sya problem ,speed can go up to 100 kph+.
    thanks
    What year model, bro?...
    9202:toothbrush:
    Apr 2009
    binaha po ba Innova niyo sir?
    Quote Originally Posted by nitram View Post
    thanks
    Check if your A/T fluid is within normal range. If not just add some. You may also drain and refill your transmission with Toyota type T-IV A/T fluid which you can purchase at any Toyota dealer.
    Apr 2005
    Quote Originally Posted by p_borj View Post
    yes.it was restore from flood.then already change a/t fluid 3x with dextron III / mercon II type.
    Apr 2005
    9202:toothbrush:
    2006 model..
    Na isolate nyo na ba na hindi galing sa makina ang hesitation?
    Pag naka neutral ba walang palyo pag bibigla ang accelerator?
    Apr 2005
    Quote Originally Posted by reym View Post
    yes.wala palya makina pag naka neutral even bigla ang accelerator.
    San nyo pinarestore? Hindi ata Dexron III ang gamit ng casa sa Toyota vehicles nila, it should be type T-IV.
    Kung sa casa nyo pinagawa and they say its ok to use Dexron/Mercon type, hinala ko yung ECU na ang nagloloko. Hindi ba ito pinalitan after ng baha? Baka meron nang bumibigay na capacitors or diodes sa loob kaya nadedelay ang ilang functions ng sasakyan.
    Apr 2005
    Quote Originally Posted by CivicVTi View Post
    ECU was replace with new one also the instrument panel.
    ATF was no sign of burn smell.
    Check engine light appear on instrument panel.
D4D A/T hesitation on D gear
