Results 1 to 5 of 5
    Mar 2007
    Hi. I just wanted to know where i can buy a transmission oil cooler. Its for a 4x4 diesel. I think any cooler will do. will a local fabricator do? Prices and contact info would be greatly appreciated. Hope to hear from you. Thanks in advance.
    Feb 2009
    Quote Originally Posted by oceanrider88 View Post
    transmission oil coolers are usually built-into the bottom of the radiator. change the radiator to one with oil cooler or you can opt for a more complicated modification of installing a ram air cooled transmission oil cooler
    kung auxilliary cooler lang kailangan mo marami sa mga surplus stores.
    May 2009
    kung ako sayo i prefer the external cooler to decrease the load of the engine radiator (for internal coolers). Kuha ko ng oil cooler 5 years ago sa bonifacio ave. area is around P1.2k plus P500 plus for the hose connections from heavy equipments.
    Mar 2007
    Thank you. Check ako sa surplus shops.
