guys, how do you know what kind of differential you have.
it seems there are conflicting how to's about it. some say example: lsd: while both wheels are lifted, on 1st gear, only left wheel will rotate, while right will only rotate if you stop the left rotating wheel... some say this means it is a open differential not lsd.
or on engine off in 1st gear and Rotate either wheel by hand and check that the other wheel rotates in the opposite direction.
and how do you tell if your lsd has worn out?
I read that if you lift only one wheel on 1st gear, the lifted wheel will spin.
