Results 1 to 4 of 4
    Aug 2008
    mga sir ask ko lang po sana baka may nakakaalam kung ano problema ng clutch ko.. kapag inapakan yung clutch pedal may nararamdaman akong nagpa-palpate. kahit konting apak lang or magsi-shift ako ng gear may nararamdaman ako. mahina lang naman po at walang audible sound pero mararamdaman po sa paa every time na aapakan yung clutch pedal. ano po kaya ang problema ng clutch ko?
    sa palagay ko either yung clutch disc or release bearing may problema
    para makasigurado ipa road test mo sa mekaniko
    May 2007
    Pedal Pulsation
    A pulsating clutch pedal is caused by the runout (wobble or vibration) of one of the rotating members of the clutch assembly. A series of slight movements can be felt on the clutch pedal. These pulsations are noticeable when light foot pressure is applied. This is an indication of trouble that could result in serious damage if not corrected immediately. There are several conditions that can cause these pulsations. One possible cause is misalignment of the transmission and engine.
    If the transmission and engine are not in line, detach the transmission and remove the clutch assembly. Check the clutch housing alignment with the engine and crankshaft. At the same time, the flywheel can be checked for runout, since a bent flywheel or crankshaft flange will produce clutch pedal pulsation. If the flywheel does not seat on the crankshaft flange, remove the flywheel. After cleaning the crankshaft flange and flywheel, replace the flywheel, making sure a positive seat is obtained between the flywheel and the flange. If the flange is bent, the crankshaft must be replaced.
    Other causes of clutch pedal pulsation include bent or maladjusted pressure plate release levers, warped pressure plate, or warped clutch disc. If either the clutch disc or pressure plate is warped, they must be replaced.....or do the cheapest first, try bleed yong Clutch Master Cylinder (CMC). If nothing change...pabuksan mo na.
    Aug 2008
    Quote Originally Posted by v6dreamer View Post
    Pedal Pulsation
    tnx mga sir!
palpating clutch (ae92)
