Results 1 to 9 of 9
- Oct 2007
- 55
July 1st, 2009 10:26 PM #1
My ride's a honda city type z 1.3 2002. I think i have a major problem with my transmission(i hope i'm wrong). Sa south super hiway kapag nagdadrive ako nararamdaman ko minsan na pag nagshift ako to second gear sa una parang ang bagal tapos mararaamdaman mo na parang biglang lalakas yung power or yung hatak. minsan naman vice versa. someitmes in 3rd gear or fourth i experience this. so what i do is i release the gas pedal then step on it again. ito po ba yung tintatawag nilang clutch sliding?
kelangn na ba palitan o mareremedyuhan pa yung transmission assembly ko?
- Feb 2008
- 325
July 1st, 2009 10:45 PM #2pag sliding clutch na problem. usually you have to rev your engine hard (high rpm) to achieve acceleration or if you need to downshift more frequently when going uphill.
pwede ring stuck-up throttle cable ang dahilan ng problema mo. Have a mechanic test drive it para madiagnose yan. good luck.
July 1st, 2009 10:47 PM #3
Does your engine rev up without the car speeding up?
If yes, then your clutch is sliding. To fix the problem, the clutch disk will have to be replaced. usually the pressure plate and bearing gets replaced as well.
BTW, have a mechanic check the clutch adjustment if there is any adjustment left for your clutch. If it's already adjusted to its maximum, no choice but to change the clutch for a new one (or "rebond" new friction material on the old clutch disk).
July 1st, 2009 11:07 PM #5
- Oct 2007
- 55
July 2nd, 2009 12:10 AM #6yes sir... sometimes parang ganun ang nararamdaman ko. pero not to the extent naman na no increase in speed. Meron pero parang minimal lang. I dont think na na adjust na yung clutch nito at least thats what i know. yung dati n may ari sa casa pinamaintain. I just dont know kung having it tuned up eh napaadjust na nya yung clutch.. ill have a mechanic check it asap sir! ..
July 2nd, 2009 09:25 AM #7
August 5th, 2009 07:33 PM #8
Hi I have the same problem, my clutch is already sliding, my mechanic told me that the clutch disk and release bearing needs to be replaced and will check the if pressure plate needs get replaced too.
August 23rd, 2009 03:55 PM #9
sa A/T po ba may clutch sliding rin? civic lxi 96 a/t po.. pansin ko kasi medyo mahina hatak eh pag normal na tapak lang..pag diniinan tapak magddownshift normally then lalakas ang hatak pero di ganun kalakas..
Are they on track to surpass last year's sales?
Car Sales Data (2025)
