Results 1 to 11 of 11
    Oct 2008
    mga sir,.tuwing kelan ba dapat ngcchange ng gear oil?
    ok lang ba every after 3 motor oil change?
    salamat mga sir
    Jun 2008
    Quote Originally Posted by steve_vai View Post
    salamat mga sir
    check your owners manual, it will say on the manual when and what type of gear oil to use.
    salamat mga sir
    if manual, yes it is ok. pero better to rely on your owners manual.
    usually its 40k interval
    yes normally thousand kilometers yan. if the manual says 40K you can replace it by 30K or earlier.
    May 2007
    The average car will never need to change gear oil. However if you do a lot of towing, or carry excessive loads. Its recomended every 50,000 miles to keep it in good shape. If you do heavy pulling probably every 25,000 miles.
    Oct 2008
    salamat mga sir! i own a mitsubishi singkit.
    i change gear oil every 40k kilometers on my mitsu pizza
    i change gear oil every 50k kms, on my pizza. i use mobil.
    Jun 2006
    Toyota Quezon Ave changed the gear oil on my Avanza at 20,000 kms. Car was 2 years old.
    Nov 2003
    every 40k is ok using decent quality gear oil. if you use monograde or not so good quality gear oil it should be sooner.
gear oil
