Results 1 to 7 of 7
December 10th, 2003 05:22 PM #1
I'm currently encountering these problems:
1. There's a very irritating noise (vibrating metal to metal sound...parang loose screw) after I release the clutch. Nawawala when I depress on it again, basta pasumpong sumpong. I also hear this when I engage the 1st to 2nd gear, pag pa-arangkada.
2. At 3rd gear parang may wavy vibrations ang buong pick-up ko pang umaarangkada but when I reach 30kph, nawawala na.
All else is fine naman. Im still having that smooth shifting of gears and no problem naman sa hatak.
Question: Do you think I need to have my clutch overhauled na? I mean alam ko na may mga parts na na nagwe-wear out but do I wait until everything gets worn-out before I have my clutch opened? Biyahe kasi kami sa quezon on the 20th eh.
My Pick-up is a Mitsu L200 4x2. How much does it cost to replace the major parts including the labor?
Your help will be very very much appreciated! Thanks!
December 10th, 2003 07:35 PM #2Originally posted by Djerms
[B]1. There's a very irritating noise (vibrating metal to metal sound...parang loose screw) after I release the clutch. Nawawala when I depress on it again, basta pasumpong sumpong. I also hear this when I engage the 1st to 2nd gear, pag pa-arangkada.
[B]2. At 3rd gear parang may wavy vibrations ang buong pick-up ko pang umaarangkada but when I reach 30kph, nawawala na.
December 10th, 2003 09:58 PM #4
Release bearing nga iyan malamang. But since the transmission is down already, might as well change the pressure plate and clutch disc.
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 15th, 2003 12:13 PM #5give richard a call in speedyfix and leave your number. he can get back to you in a couple of minutes with the price for the pull down of the tranny as well as the parts that need to be changedÜ
thanks!
- Nov 2003
- 3,848
it would take a good load of checking, and even then, things could always still remain honestly...
[Tsikot official] Where do you buy used cars?
