Results 1 to 3 of 3
    Aug 2012
    Car: Nissan Sentra 1989 Model
    Problem:
    1. Hirap pong pumasok sa 4th gear and maingay ang 2nd and 3rd gear.
    2. After 30mins of driving, tumitigas pong apakan yung clutch.
    Ano po kaya ang posibleng sira or dapat ipacheck?
    Any recommended shops na rin po na pwedeng puntahan. San Juan Area po ako.
    TIA
    Jul 2010
    *bexxprojects,
    Problem:
    1. Hirap pong pumasok sa 4th gear and maingay ang 2nd and 3rd gear. - Try replacing your transmission fluid first and see if the condition has improved
    2. After 30mins of driving, tumitigas pong apakan yung clutch. - I think its time to replace the clutch disc, pressure plate and release bearing if you are experiencing this problem.
    HTH
    Aug 2012
    Thank you sa reply sir xtian119
    1. Napalagyan ko na ng transmission fluid yung oto namin. Smooth na yung shifting ng gears. Wala ng ingay.
    2. Clutch Disc, Pressure Plate and Release Bearing - eto na ang next na papapalitan ko. Ipon-ipon muna.
    Salamat sa mga forum na ganito at sa mga taong matyatyagang sumagot sa mga tanong. Malaking tulong kayo sa mga baguhang tulad ko
Clutch and Transmission Problem?
