pano po magcheck ng fluid sa manual transmission?
wala yatang pang-check yun eh like on A/T cars.. so pag nadrain mo sya (hopfully di pa sya putik putik) palitan mo na din..
Unlike automatic trans, there is no dipstick for manual trans and to check the fluid level you must crawl under the car and remove a fill plug. Mahirap ano? On ur next oil change, or when ur car is up on the lift, just ask the mechanic to check it for you. Normally they will just dip their finger on the fill openings.
salamat po sa mga reply...
ipapa-check ko na nga lang po pag nagpatune-up ako...
maybe next week...
thanks po uli...
you can drain the tranny oil and check.
and kung sa tingin nyo okay pa yung oil, pwede nyo naman ibalik yan ulit sa transmission, done that and no problem at all.
Kung isawsaw mo lang yung daliri mo dun sa loob tranny, it won't tell you much about the oils condition unlike kung i-drain nyo at makita nyo ng maigi yung oil
Siguro kung di na maganda yung texture ng oil or kung masyadong maitim/madumi na then pwede mo na palitan.
I remember in my previous car sa sobrang tagal nya di napalitan ng gear oil, sobrang lapot na ng oil ang tagal i-drain, pinalitan na namin.
I have no idea sa presyo kasi ang ginamit ko ngayon eh yung Redline MT90 (may kamahalan) kasi may tama na sa loob yung tranny ko eh.
You need a pressurized hose to fill-up M/T oil. Save yourself the trouble and have a gasoline station do it for you. Mura lang naman labor sa kanila, wala pang P200.
you can also use oiler (hand pump operated) if you wan to use your preferred
brand. crosswind's manual requires sae 15-40 motor oil for m/t transmission.
gas stations only offered sae 90-140from their dispenser for both
tranny and differential.
mga sir,
balak ko po kasi DIY n lng yung change oil tska palit ng spark plugs e!
tanong lang po ano maganda brand ng spark plugs?wag nmn po yung mga iridium plugs kc parang ang mahal e!
tpos po tungkol dun s transmission fluids e pwede pagawa n lng sa shop, magkano po kya aabutin?o pwede ka bili ng sariling mo tansmission oil tpos palagay mo n lng?ilang liters po b kailangan pag mitsu galant yung ride?
slamat po uli mga sir![]()
galant pala tsikot mo. mahirap i-DIY yan. unlike sa mga pick-ups na madali lang kasi mataas ang ground clearance. pa-service mo na lang sa mga gasoline station. don't ever use jack (kahit na corcodile jack pa yan) then susuot ka sa ilalalim. very dangerous.puede pa siguro if may two jack stands ka. but there's also a probability na mag-slip pa rin ung jack stands.
for the right transmission oil to be used, check first the owner's manual. then from there, select a brand suitable to your budget.
regarding naman sa changing of spark plugs, dapat ung right plugs specified by your manual again. iba-iba kasi ang design ng mga spark plugs. and i think hindi mo pa ata kayang magpalit ng spark plugs. let the skilled mechanic do it for you then paturo ka na lang so next time kaw na magpapalit..![]()
