Results 1 to 6 of 6
    Oct 2005
    Mga tsikoteer ? pls. give idea about my ride honda A/T .
    i heard a weird sound na pag natapak ng gas pedal .... seems para nagmumugo sounds like "gluk..gluk ".... but iyon takbo naman no problem and speed. It seems hindi siya ganoon ka smooth ang sound. Do you think it related as ATF or sa engine or sa air intake ?
    I know how hard to analyze unless you had heard this in actual. i hope you can help ..
    appreciated your advise.
    May 2005
    I don't know its the same as ours. Also hear something like that put when depressing the brake pedal in very low speeds like manuevering in tight spots.
    '93 and '94 Civics. 2005 CRV.
    Oct 2005
    mine is when pressing the gas pedal, there is a sound gluk gluk.... when i checked hindi naman sa simota air filter nagagaling. i dont know kung tranny or engine ? .... I hope some of our collegues in tsikot might help us ....
    Nov 2003
    since it's hard to diagnose, you might want to show a mechanic so checks can be made there and then. hirap nga alamin yung ganyan online.
    Aug 2008
    Try to check the ATF baka marumi na by blotter testing on a tssue paper. Drop at least 3 on it then observe if the fluid will spread out and the fluid is in good condition . But if remain small its time to replace and fill fresh fluid. If the problems persist, may ipapakilala ako bumabaklas nyan. Bihira lang kasi sila dahil may special tools and honda:secret:
    hinde po normal yan. mas maganda siguro ipa check nyo na sa mechaniko, hirap masiraan ng AT. kelan ho ba kayo huling nagpalit ng ATF?
A/T = weird sound honda Civic  pls give idea
