Results 221 to 230 of 370
December 17th, 2016 12:41 AM #221
- Jun 2005
- 3,774
April 10th, 2017 09:35 PM #222Sa mga nagpadialysis ng honda and used a cheap ATF then honda ATF ang final na ginamit, nagkaroon ba ng damage ang mga ATF nyo?
BANNED BANNED BANNED
- Jun 2007
- 122
April 12th, 2017 07:24 AM #223Kalokohan lang Dialysis na yan. Napakadaming klaseng ATF. Hindi lahat ng ATF pwede. May multi vehicle ATF na di kasama Honda. Meron din pwede sa Honda ATF-Z1 pero di pwede sa ATF-DW1 katulad ng Spirax S5 ng Shell. Kelangan mong palitan ATF including yung nasa Torque Converter kung mali nailagay mo.
Bilhan mo na ng ATF Cooler tapos bili ka rin ng Inline ATF Filter(1k) sa Honda. Directional yung flow filter. Di mo na kelangan pang mag change ng ATF. Filter na lang papalitan mo at add ng konting ATF.
April 12th, 2017 09:07 AM #224
Imho as long as the ATF manufacturer is a trusted brand and it meets your ATF specs, you should be fine. Naka list naman sa bottle yung different specs na namimeet nya.
April 19th, 2017 05:48 PM #225
Agree with this one. For sure the manufacturer will sue anyone who falsely claim to be a producer of any product that is approved by the manufacturer. There is a cost in applying for certification iirc. The producer would surely want that certification in their package to tell the world that they do pass certain criteria or standard.
July 16th, 2017 09:10 AM #226
Due na ko for ATF replacement for my Santa Fe that requires SPIII . Naka 50,000kms of mostly heavy traffic driving na since last replacement ko ng ATF. Now wala na daw Transmax sa Ace Hardware.
Anyone tried Mitasu Multi Vehicle ATF? 1710 pesos sa True Value. First time to see a Multi Vehicle ATF na pwede din sa CVT as per specs below.
MITASU JAPAN MULTI VEHICLE ATF Synthetic Blended - synthetic, highly effective universal liquid for automatic transmissions, is suitable for the broad range of application. The innovation formula of this product guarantees smooth gear shifting in automatic transmissions of the car. High viscosity index provides effective greasing of details at the most high temperatures of service or low starting temperatures. Liquid for Automatic Transmissions of MITASU JAPAN MULTI VEHICLE ATF Synthetic Blended meets the requirements of the JASO 1A tests (Japanese Automotive Standards Organization) and HONDA.
APPLICATION
MITASU JAPAN MULTI VEHICLE ATF Synthetic Blended is widely used in cars of the Japanese and Korean producers. Possesses anti-vibration properties. Is suitable for some hydraulic transmissions, mechanisms with servoupravleniye and hydraulic to system. Is suitable for use in variators with engine displacement up to 2 l. also conforms to requirements of the LFW-1 test.
THE ADMISSIONS / PRODUCTION TECHNOLOGY MEET THE REQUIREMENTS
Completely is suitable for the following models of automatic transmissions and variators:
• TOYOTA AFT TYPE T-IV, T-III, D-II, D-III
• TOYOTA JWS 2312D, JWS 3309
• TOYOTA #08886-81015, #08886-00405
• NISSAN MATIC FLUID D, J, K
• HONDA ULTRA ATF-1, ATF Z-1
• MITSUBISHI DIA QUEEN ATF SP-II, SP-III
• MITSUBISHI ATF-II, ATF J2, PSF3
• SUZUKI AT Oil, Oil Special
• SUZUKI S-CVT
• SUZUKI ATF (5D06), (2384K)
• SUZUKI ATF (3314), (3317)
• SUBARU ATF, ATF-HP, i-CVT Fluid
• SUBARU ECVT Fluid
• MAZDA ATF D-II, M-V, F-1
• ISUZU Besco ATF-II, III
• HYUNDAY/KIA: Red-1, SP-II, SP-III
• FORD M, MERCON
• GM D-III
• MERCEDES-BENZ 236.9
• CHRYSLER ATF +3/+4
• DAIHATSU Ammix ATF D-III Multi
• HINO Blue Ribbon ATF
Technical characteristics
Technical quality Method Result
Density at 15 °C ASTM D-4052 0.8478
Temperature of flash, °C ASTM D-92 198
Temperature of hardening, °C ASTM D-97 - 45
Color Visual Red
Viscosity index ASTM D-2270 181
Kinematic viscosity at 40 °C (cSt) ASTM D-445 38.3
Kinematic viscosity at 100 °C (cSt) ASTM D-445 7.41Last edited by jmpet626; July 16th, 2017 at 09:13 AM.
July 24th, 2017 04:37 PM #227
July 24th, 2017 07:31 PM #228
I looked for specs on suzuki scvt fluid. parang wala naman application, maybe its for early gen cvts...
- Jul 2016
- 17
August 9th, 2017 03:57 AM #229Good morning mga sir! I just have an inquiry regarding changing ATF. I want to completely change the fluid inside my tranny. I asked a mechanic ng friend ko and sabi niya na no need na daw for a dialysis. Ibaba lng daw oil pan at linisan then refill. Question is pag drop oil pan lang diba hindi natatangal lahat ng fluid lalo na yung nasa Torque Converter? And besides ang alam ko advisable lang eto for manual tranny which is drain and refill (correct me if I'm wrong). Previously manual car ko but now ng palit na ako ng automatic. Really confused. Ano ba mas maganda for a complete change in ATF. Worried na din kasi ako dahil parang may burnt smell na ung fluid the last time I checked. BTW, ride is Mitsu Lancer 98 GLXI AT with InvecsII/sports mode transmission. Really appreciate all feedback and comments. post lang mga sir. maraming salamat and more power sa forum na eto.
August 9th, 2017 06:26 AM #230
Personally, I don't trust Mitasu. It's not even made in Japan (Russian-made). Then there's these text about it being "Manufactured by an ISO 9001:2008 certified company for Mitasu Oil....".
Then there's also its claim that this same oil can be used in both traditional A/T and CVT... what a load of c!*p!
It also uses the word "Suitable" when talking about compatibility with different transmissions. Anyway, before you pour that thing into "the most complex piece of machinery in your vehicle" (the A/T), watch the following video.
Transmission Fluid Facts - YouTubeLast edited by oj88; August 9th, 2017 at 06:30 AM.
Advertised Battery Range of the SL6 is 100km on Pure EV mode but the computer inside the unit will...
BYD Sealion 6 DM-i
