Results 1 to 10 of 370
    Mga sirs, paano pag normal na change ng atf fluid lang, ilang liters kaya ang city 06? Tia!
    Dec 2009
    Quote Originally Posted by ecneret View Post
    im sure sir nasa manual po sir yung amount nang ATF po sa honda city 06, if wala sa inyo manual you can ask the casa, they know it for sure...
    the earlier you change the ATF before its recommended life much better,, heat is the primary enemy nang atf fluids...
    that's why synthetic ATF last for a minimum of 80,000kms.
    as the vehicle is driven, the atf fluid gradually changes its color due to oxidation, sa una hindi mo makita na madumi na kase usually pag tinignan mo mapula pa (naked eye) , pero pag naka kuha ka nang around 1 liter at nilagay mo sa transparent na bote, makikita mo nadark na siya.. hindi na red, parang nearing brownish color na...
    if the atf fluids gets to the point of becoming brown-dark brown,,the transmission is in serious risk of getting damaged, dahil hindi na correct yung atf properties plus the wear will increase drastically causing problems on the valve bodies and solenoids inside the tranny...
    Aug 2012
    Kung sa years, paano ang sukatan kung kelan mag change atf? Kasi aabutin ng 6 years bago ako maka 40,000 kms.
    Ang honda vehicles pwede ba gumamit ng non-honda brand atf?
    Oct 2011
    may dipstick para sa ATF. pwede tignan ung color appearance, level (if hot or cold) and ung smell ng fluid.
Changing ATF Fluid completely (DIALYSIS PROCESS)
