Results 1 to 11 of 11
    Aug 2013
    Patulong naman po sa Mitsubishi Lancer 2009 GLX
    Yung kotse ko di ko mashift yung gear pag binuksan ko na yung makina pero pag nakapatay nalilipat ko naman. Gumagana siya kahapon dumaan ako sa baha at huminto muna sa SM sa amin, nakauwi pa ako sa bahay at ngayong umaga di na bigla ma-shift ang kanyang gears.
    Tinignan ko yung clutch fluid okay naman, yung power steering below minimum na kaya nilagyan ko ng power steering fluid. Ayaw pa din magshift. Ayaw ko na mangalikot baka ano pa mangyari kaya nagtanong ako dito. Pudpod na kaya ang clutch ko? Magkano kaya ang aabutin pag pinapalit ko ito?
    Salamat sa mga sasagot.
    Sep 2006
    Quote Originally Posted by mooky View Post
    Have your master cylinder checked...
    Apr 2010
    Baka kinalawang ang clutch pressure plate at flywheel dumikit ang clutch disc ayaw na ma disengage kaya ayaw mag gear shift. Or baka ang clutch master cylinder mo hindi tumutulak ng tama.
    Feb 2009
    Quote Originally Posted by Vootlog View Post
    it had been raining lately and you probably drove your car in the flood. the most probable cause is rusted pressure plate and flywheel. try shifting to fourth gear and with the clutch pedal depressed, have the car pushed (nudged) forward and back. this usually releases the clutch disc from the rusted pressure plate and flywheel
    Jul 2010
    Nangyari din sa Lancer Itlog ko iyan after lumusong ako sa baha at park sa mataas na lugar. Inilagay ko sa 1st gear kasi inclined yun park sa bangketa.
    Nun kunin ko na kotse ay ayaw na shift sa 1st, 2nd, 3rd at 4th. So ang ginawa ko ay off ko muna engine. Taas handbrake. Shift ako ng Reverse at pumasok naman. Then Start yun kotse.
    Okay na uli shifting ng kotse. Inabutan pala ng baha yun release bearing kaya na-stuckup.
    Feb 2009
    been waiting if someone would catch this. so far nobody replied with the other way around:
    put the transmission in gear, apply the parking brake, step on the clutch and crank the engine
    i feel this suggestion may be a bit dangerous... it might cause complications.. i find your first suggestion (put in gear, then nudge back and forth the car) better.
    Aug 2004
    Depends on why this it's stuck.
    One of our trucks had trouble shifting after driving it through flood.
    Just turn it off, put it in first, start with the clutch fully depressed.
    Then every shift afterwards, rev match to make it go in.
    After a dozen kilometers or so, it loosened up na.
    Jul 2006
    My W123's are suffering with this nowadays. Before I move them, I have to rock them back and forth. W123's are not exactly light cars ...
    Aug 2006
    Happened to my Lancer when my wife drove it s flood about almost nakalapat na sa ilalim. The next morning hindi maka shift ng gear..
    I made a little research.. and saw somebody suggested here to shift it to 1st or 2nd gear ata.. Press the clutch and start the engine. You will hear a noise after starting the engine.. parang noise na natanggal sa pagkakakapit...
    After that nag ok na.. Drive the car a little bit para mag loosen kung ano mang kumapit..
    Wala na problem after nun...
    Lesson.. as much as possible wag idaan ang kotse sa baha specially pag sobrang lapit n ng tubig sa pang ilalim...
    Apr 2018
    Quote Originally Posted by xander1925 View Post
    Pa-help naman po, naexperience ko po kasi na hinde ako maka-shift ng gear kapag naka turn on yung engine. Pero pag naka turn off naman po, nakaka shift ako sa kahit anong gear. And i noticed po na biglang malambot apakan yung clutch ko, parang wala ako inaapakan. i checked on the clutch fluid sa may engine, wala ng laman.
    Ano po bang fluid pwede ko gamitin? wala din naman pong signs ng leak sa may engine. Ano po kaya problem ng FD ko? and baka meron po kayo ma-suggest na reliable mechanic, makati area po sana.
Gear won't shift while engine is running.
