Results 1 to 3 of 3
    Feb 2007
    good day mga paps..question lang, where makikita or check ang transmission fluid or gear oil..corolla gli 99 m/t..thank you tnx..
    Feb 2009
    Quote Originally Posted by siat69 View Post
    your transmission is equipped with two plugs for servicing gear oil, one on the lowest part is the drain plug, the other on the same level as the driveshaft is the filler plug. the fluid is properly serviced if you can reach the fluid level to the first joint of your finger or up to the same level as that of the filler plug hole
    Feb 2007
    Tnx tnx bro..
corolla lovelife gli 99 m/t..transmission fluid..
