Results 1 to 5 of 5
    Jan 2012
    Mga boss,
    I have an opel tigra, converted ung engine to sentra GA15, originally manual ung tranny ng engine, recently converted to AT.
    nang makuha namin ung car from the shop na gumawa ng conversion, napansin namin na walang D. from neut S na agad.
    at first ang problema lang is mis aligned lang shift stick at matagal mag upshift. kailangan umabot sa 3.5k to 4k ang rpm bago mag upshift. Pagnagslowdown naman di ramdam ang down shift.
    tapos after a while, pag mainit na ang engine (and I suppose the tranny din), hirap na pumasok ung reverse. kailangan pang bumalik sa park bago papasok reverse.
    we tried replacing the ATF twice na. hindi parin nag change ung upshift at mahirap parin pumasok ang reverse pag medyo mainit na ang engine.
    we also tried cleaning the filter of the tranny pero wala paring pagbabago.
    tapos recently, nawala na ung reverse. kahit cold or hot ayaw na pumasok ung reverse.
    I hope na matulungan nyo ako mga boss.
    Tnx in advance.
    Jul 2006
    Why "clean" the filter? It's disposable AFAIK. Sa Benz, pag ganyan ang symptoms ... most likely its a clogged tranny filter.
    Jan 2012
    pasensya na boss... kung clean filter ang first aid... yun kasi nabasa ko sa net e.
    Oct 2009
    he he nasa wild west na akets )
    marami sa nissan strainer ang gamit kaya ok lang linisan kung hindi masyado marumi and barado screen. AFAIK 2 klase ang ginamit na trans; hydraulic and electronic. since transplant ito, pag electronic ginamit ay hindi na gagana ng matino ang trans. kung hydraulic naman dapat maayos na mabuti ang throttle control, pero sa kaso mo more likely the trans is shot and need na irebuild
95 sentra late shifting, no reverse
