Results 1 to 4 of 4
    Apr 2003
    Normally I see discussions of clutch problems related to hard shifting into gears. But what does it mean pag problem shifting out. stuck kahit na fully depressed ang clutch. And sa first gear lang.
    Sep 2012
    Possible scenarios kung bakit ganyan sa iyo
    1) Clutch cable adjustment
    2) Other troubles in clutch assembly
    3) Worst case there is a problem with your synchronizer in the transmission
    Sent from my Windows Phone 8 using Tapatalk
    Dec 2013
    Quote Originally Posted by icon View Post
    Then maybe your problem is with the shifting and selector cable.
    Feb 2009
    What vehicle might this be? Check your shifter cables or linkages. Lubrication might have dried up or something might be interfering with its free movement. The first gear and reverse gears are not synchronized nor equipped with synchronizers
Hard shifting out of first gear
