Results 1 to 10 of 10
April 8th, 2012 10:27 PM #1
I drive an old car that uses only Dex II ATF. Any recommended brands? Dex III ATF sells for around Php200/liter in Banawe nowadays. Top1 brand I think.
Just looking for some Dex II in that price range or less also. =) thanks. Dex III is easier to find nowadays.
April 10th, 2012 02:37 AM #2
Sir Otep, please correct me if I'm wrong - most DEXRON-III/MERCON ATF conforms to DEXRON-III specifications.
Anyway, there's this super cheap ATF available in most auto supply stores. I think it follows DEXRON-II specs.
Its packaged in cheap plastic bottles, I just really forgot the brand. Try going to Visayas Ave.
April 10th, 2012 03:04 AM #3
Dapat ata matanong si BlueGirl regarding this since she's the lubes specialist at Shell. hehe. Hindi ko din alam with regards to cross compatibility, eh.
April 10th, 2012 07:30 AM #4
DEXRON
DEXRON - Wikipedia, the free encyclopedia
Dexron
The original Dexron fluid, like its predecessor Type-A/Suffix-A, used sperm whale oil as a friction modifier. The U.S. Endangered Species Act banned the import of sperm whale oil, so Dexron fluid had to be reformulated.[1]
Dexron-II
Dexron-II was introduced in 1972 with alternative friction modifiers such as Jojoba oil. However, it made problems with corrosion-prone solder in GM's transmission fluid coolers and so had to be reformulated.[2]
Dexron-IID
Corrosion inhibitors were added to Dexron-II to address the solder corrosion issue. The resultant fluid, released in 1975, was called Dexron-IID. However, the corrosion inhibitor made the new fluid hygroscopic to a problematic degree, and so had to be reformulated.[2]
Dexron-IIE
Dexron-IIE was introduced in an effort to address the hygroscopicity problems with the previous IID fluid.[vague]
Dexron-III
In 1993, GM released new Dexron-III fluid. It is generally backward-compatible with transmissions originally filled with earlier Dexron fluids or with Type-A/Suffix-A fluid.
Dexron-VI
The fluid specification for Dexron-VI was introduced in 2005,and was first used as the GM factory-fill automatic transmission fluid for model year 2006. All Dexron-III licenses expired permanently at the end of 2006, and GM now supports only Dexron-VI fluids for use in their automatic transmissions.[3] Fluids asserted by their manufacturers to meet Dexron-III standards continue to be sold under abbreviated names such as Dex/Merc, but the licensing system no longer exists. These fluids are not regulated by GM.[citation needed] Dexron VI is of a slightly lighter viscosity than the prior Dexron fluids. The intent of this lighter viscosity is to gain an incremental improvement in fuel economy by lessening parasitic drag in the transmission.
April 10th, 2012 12:03 PM #5
So in this case, Dexron III fluid should be compatible with older (Dex-II) transmissions (based on the chart above).
April 10th, 2012 04:36 PM #6
Kulay red na muntik ko pa di makita. Salamat sa advice. Hirap talaga pag luma sasakyan. Hehe
- Jan 2008
- 172
April 15th, 2012 01:53 AM #8i dont know if its the correct word, but DEXRONIII supercedes DEXRONII. DEXRONVI supercedes both III and II.
VI is pricier though. Go with DEXRONIII
- Sep 2011
- 626
May 22nd, 2012 03:03 PM #10Mam/Sir, goodafternoon ho. I have a question lang regarding ATF.
Since recommended sa manual to use SP3 ATF, pwede ko ba gamitin yung ATF+x ng chrysler?
Tama din po ba yung understanding ko na I can use any ATF grade placed "above" what the manufacturer recommends?
ie: I need SP3. Since Dex3 is placed higher, I can substitute it for SP3 even if it is on a different column.
Thanks Mam/Sir.
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
