Results 1 to 12 of 12
    May 2009
    hello uli mga kuya.
    pasuyo naman po ng alam nyong shop at saktong address sa banawe na nagbebenta ng mga transmission coolers. para mas mabilis ang aking lakad kapag nagawi doon. galing pa kasing probinsya.
    maraming salamat.
    Apr 2013
    I like to know thiss too. Kailangan ko rin ng cooler for my matic jeep. From what I've heard sa mga surplus around Imus may mga nagbebenta then someone suggest me na ang kunin ko yung radiator na may kasama ng line for the matic transmission.
    Aug 2004
    Yup usually built in sa radiator ang ATF cooler. You can use the small oil coolers though.
    Sent from my GT-N7000 using Tsikot Forums mobile app
    Hi guys,
    Im curious about this add on oil filter para sa AT. I currently have a AT W/ a 1KZ-TE engine. Ano bang magandang additional na oil filter?
    Btw, I chabge fluids every 2 years w/ RP atf and thats regardless of the odo reading. 2 years will count less than 10k for 2 years for me. So advisable bang baklasin yung oil pan ng AT para malinis ng husto?
    TIA guys....
    Posted via Tsikot Mobile App
    Sep 2013
    Masyado matagal yung every 2 years na change oil. Imagine 24 months yung langis sa engine mo. Gawin mo 12 months ang change oil para hindi gaano katagalan.
    If pwede sa engine mo ci-4/sL na oil yun na lang gamitin mo mura pa price pero quality formulation. (mobil delvac mx, delo gold, top 1 sdo, zic up.....etc)
    Pero kung sm sn rating ok na din valvoline durablend and zic a or zic a+
    Kasi kung namamahalan ka sa royal purple kaya every 24months change oil mo eh gamit ka na lang lower price na oil na at par or mas quality pa. Tapos change oil ka once a year or 10,000 to 12,000kms kung sino mauna.
    ^ Yung ATF ng sa akin since 2010 hindi pa napalitan and nung pinacheck ko last month ok pa daw. Hinihintay ko na lang 50k kms odo reading para mapalitan. Although mas beneficial yung ginagawa mong 2 years kasi fresh ulit, hindi practical.
    Sent from my iPhone using Tsikot Forums
    Jun 2006
    di ba lahat ng a/t transmission meron na built in cooler? naka divert na ang fluid papunta sa ilalim ng radiator.
    my 1999 lovelife and gen3 vios has this.
    Aug 2004
    Quote Originally Posted by shibby75 View Post
    Meron pero it's designed to take care of normal AT usage. Kung lagi kang umaakyat ng bundok, nagkakarga ng mabigat or kumakarera a bigger ATF cooler is needed to get rid of the extra heat.
    Sep 2013
    Quote Originally Posted by beni23 View Post
    Binasa ko ulit yung post # 4 mo. Mali pagkabasa ko, effecto ng madaling araw na inaantok.
    Kung atf fluid pala tinutukoy mo. Every 40,000kms ang palit.
    Hi guys,
    Thanks for your replies. Sorry if medyo misleading yung inquiry ko dahil nabanggit ko yung engine. So yung every 10K na change ng atf fluid ay waste of money lang?
    Pwede ko bang lagyan ng additional oil cooler yung return line ng AT ko? May nakita kasi ako sa mga motorcycle shops na oil cooler na pang motorcycle, makina nun ay usually 110cc to 125cc lang. Medyo maliit nga lang yung lines compared sa stock na nakalagay so uubra kaya yun?
    Mayron bang mga shops na nagbebenta ng mga oil coolers talaga?
    TIA..!
    Apr 2013
    Quote Originally Posted by erick_214 View Post
    Hi guys,
    TIA..!
    tingin ko if for daily driving lang it will do. pero iba pa rin yung para talaga sa kotse na oil cooler for the AT fluid. ako naman nag hihintay na lang ako mag palit ng radiator na may kasama ng line for the AT fluid. itatanong ko rin nga yan dito sa mekaniko sa amin.
    Sep 2013
    Hi guys,
    TIA..!
    Oo nagsasayang ka resources. Check mo car manual kung ano nakaindicate kms/year para magpalit atf.
Shop na nagbebenta ng mga transmission coolers (for A/T)
