Results 1 to 5 of 5
    Oct 2009
    Help, hirap po magshift sa 1st gear from stop or downshifting pag sumasabit parang nagkakaskasan na gear, kailangan ko pa diin na sagad na sagad pagka depress ng pedal bago ko maishift sa 1st gear.
    Hindi naman sliding, hindi naman matigas tapakan, mahirap lang talaga ishift from neutral to first gear or pag mag dodownshift ako. Parang kailangan ko tangalin un carpet para madepress ko ng maayos para maishift un kambyo. Kailangan lang ba ng adjustment nito?
    Thanks.
    Feb 2009
    If your car has clutch cable, it might need adjustment to compensate for wear. Or check your transaxle lube for quantity and condition. Idle speed is also a factor.
    Nakiki wi-fi lang
    Oct 2009
    Nakiki wi-fi lang
    Yes sir clutch cable po, saan po ako mag aadjust? Sa clutch pedal or sa fork ng cable sa engine bay? Pasikip or paluwag dapat ang cable?
    Thanks.
    Feb 2009
    Adjust to lengthen the cable slightly to give a slack and secure your adjustment
    Nakiki wi-fi lang
    Oct 2009
    Nakiki wi-fi lang
    Thanks sir gagawin ko agad yan.
Cable clutch
