Results 1 to 3 of 3
    Mar 2013
    Tanong lang po sa mga naka hyundai accent crdi 7DCT or ibang nakadual clutch. Normal ba na pag nagfull stop ako tapos pataas yung daan tapos pag magaaccelerate na uli, may "tok" na tunog sa harap ng sasakyan? di kagad siya magaaccelerate na parang nakadisengage yung clutch tapos pag nagengage na clutch, dun tumutunog.
    Isang tunog lang siya na ang tunog niya, parang pag ilang linggong di nagamit yung koche tapos dinisengage mo hand brake..parang bakal na nagdikit tapos first time maghihiwalay na tunog..
    300kms palang natatakbo nung koche. Alaga naman ako sa transmission pag trapik.
    Sent from my SM-G920F using Tapatalk
    Feb 2009
    Your car's clutch is pull type. Check the hydraulics first. The release bearing might be sticking to the input shaft tube and does not slide smoothly. It might get better with time or if not, you might need to take the transmission out and clean/relubricate the clutch release fork, release bearing bore and the clutch release bearing face. Use high temperature grease sparingly.
    Mar 2013
    mukang alam ko na sir yung sagot, yung hill start assist ata yun..naghohold ng brake for 2secs kaya after ko bitawan yung brake tapos tinry ko gasan kagad, tumutunog yung brake dahil sa hill start assist..kaya after 2 seconds biglang parang kumakagat yung clutch, kasi bumitaw na brake..pero the whole time nakaengage na malamang yung clutch..
DCT noise on uphill/inclined
