Results 1 to 5 of 5
    Dec 2009
    Mga kapatid, I need your opinion. I have a Honda City 97 Model M/T. Hindi makapasok sa kahit anong gear kung cold ang engine. What I do is pinapa warm up ko muna mga 3 mins para makapasok, pero even then, pahirapan pa rin. Naririnig ko nagca-clash ang mga gears dahil pinipilit ko. Pero kung naka larga na, ok naman, smooth shifting naman.
    This happens kung mga at least 3 days ko hindi nagamit ang car (mahal kasi toll sa amin kaya bihira ko lang gamitin, ususally weekends lang). Kung nagamit ko ang car the day before, yung reverse lang ang medyo matigas, but the rest of the gears smooth naman.
    Ano kaya ang diperensya? Thanks for your opinion.
    Jul 2010
    Napa check mo na ba yun Transmission Oil?
    Dec 2009
    Quote Originally Posted by Chinoi View Post
    Boss Chinoi, thanks sa reply. Pinalagyan ko ng transmission oil nung 2011, sinabay ko sa tune-up at change oil. Since then, hindi ko na napapalitan.
    Jul 2003
    Possible cause:
    1. Sticky Clutch Disc
    2. release bearing stucked
    3. Low on Transmission oil
    4. Higher than normal engine RPM when cold
    Dec 2009
    Quote Originally Posted by tip_tipid View Post
    Possible cause:
    Boss tip, thanks for the reply. Will quote these kung magpatingin ako sa mekaniko. Mas maganda kung may mga suggestion ako para hindi ako magmukhang madaling mauto...
hard to shift manual transmission on cold engine
