Results 1 to 20 of 20
    Sep 2013
    something odd happening in my sedan MT is not smooth shifting. Checked & observed the ff
    1. no leaking
    2. replaced the fluids already 5 months ago
    3. no burning smell
    4. no gears slipping but sometimes, it's difficult to shift into reverse gear.
    what do you think is the cause of a problem or defect??
    Sep 2008
    Quote Originally Posted by kimbon View Post
    1. no leaking
    3. no burning smell
    Most likely a clutch problem, what is your mileage? It could be either the clutch slave or the clutch disc/pressure plate
    1. no leaking
    3. no burning smell
    Sep 2013
    ^^ 41k mileage. at saka pansin ko medyo stiff na rin ang clutch pero manageable pa naman. never pa naibaba ang clutch nito..
    Sep 2008
    your mileage is so small para maging clutch disc/pressure plate problem unless you are a clutch driver or something extraordinary is wrong with it. I would rule it out, so I would like to think it is a clutch slave issue. Baka naman all it needs is a little adjustment sa clutch lever to make shifting smoother. Mababa ba ang clutch?
    Jan 2011
    shifter bushing, baka pudpud na. it is made of plastic. around 50 petot/pc yata. usually palitan mo 8 pcs. just have it check pag medyo sumasabit. madalai lang ikabit po yan sir. you can even have it DIY, kung yon nga ang culprit.
    Sep 2013
    Quote Originally Posted by jakewise View Post
    di naman mababa or mataas kundi nasa gitna lang. di pa ito na-adjust or nagalaw since nabili ito ng brandnew
    nope di talaga ako clutch driver. kung minsan nga nanginginig na ang makina saka ko pa lang press ang clutch pero bihirang bihira lang ito mangyari. hehe
    Sep 2008
    if you are sure na walang leakage including where the clutch slave is located, you might need to check the internals ng clutch slave, baka ang rubber cups ay malambot na. There is a repair kit for that
    Sep 2013
    Quote Originally Posted by shelu View Post
    shifter bushing? saan ko kaya makikita ito sa pang-ilalim o sa loob rubber boots ng kambio? nasa youtube DIY ba to? TIA
    Sep 2013
    yup talagang walang leak. kapag umaalis ako sa parking ko i check yung floor kung may tagas na any fluids. tubig lang galing sa a/c
    1. no leaking
    3. no burning smell
    What is the make and model of your car?
    You mentioned that you changed the transmission fluid quite recently. Is there a chance that the mechanic used the wrong type of fluid? IMO, your mileage is quite low to be experiencing this type of problem.
    Sep 2013
    Quote Originally Posted by CivicVTi View Post
    yup I agree... mileage is so low, I opted to post here maybe some of you have already experienced this issue. I bought the fluid in Toyota, gen10 altis is my car BTW.
    Oct 2013
    funny as it sounds, toyota sells the wrong type/viscosity of manual tranny fluid. go check your user's manual and compare with what toyota sold you...
    Sep 2013
    Is the shifter bushing connected to shift forks???
    I have a habit of resting my right hand on the shifter while driving even for A/T. Would it possible i put enough pressure on the shifter resulting to wear & tear on the shift forks over time.
    Quote Originally Posted by Stigg ma View Post
    nope I don't think so. I definitely bought the right type of tranny fluid in casa besides all M/T fluids can be used in all toyota variants. FYI
    Sep 2008
    TS, what's the update with your transmission??
    Sep 2013
    up ko lang 'to. baka may idea kayo kung saan located ang shifter bushing l???
    di ko pa napapagawa eh pwede pa naman pagchagaan. busy lang lately
    Sep 2008
    keep us posted, thanks
    Sep 2013
    ^^^ sure no problemo... ganito rin ba na not smooth shifting ang M/T natin??
    Apr 2009
    the shifter bushings are located beneath the shifting lever trim. You have to remove the trim to visualize them. They are located in the "joints" b/n the cables and the shifting lever. Your car is still relatively new for the shifter bushings to fail but it is worth checking as these are relatively cheap parts and easy to replace but can be bothersome if they have seen better days. It could also be that you have a leaking primary or secondary clutch master or if you are a "clutch rider", you might need a new clutch
    what gear oil did you use on your gear oil change
    Feb 2012
    TS baka same nangyari sakin yan, nag start parang sticky lahat ng gears specially 5th gear, tinitiis ko kasi busy araw araw sa work, hangang 1 day bigla nalang ayaw mg engage ng kambyu at na stock cya sa 4th gear while on the highway. Kinabahan ako at pinilit kung maiuwi sa bahay kaysa ma tow ako sa kalsada. Pinilit ko maiuwi on 4th gear pagdating sa bahay amoy ang clutch. Haha. Then next day i called tow truck to bring it to my trusted mechanic. Long story short, ung parang shifter bushing ang natangal. By the way my car chevrolet aveo manual 2008 sedan(singapore)
    Mileage 150k na nung nadali. Walang parts s chevrolet order padaw, then ung mekaniko here ginawan nalang paraan nagpagawa cya sa machine shop, now ok na.
Manual Transmission not Smooth Shifting
