Results 1 to 10 of 13
June 5th, 2013 03:58 PM #1
I need help po sa mga nakaka alam dyan kung paano po aayusin yung sa OR/CR ko po..
yung sa OR/CR ko po kase nakalagay sa Fuel type eh "DIESEL" pero dapat po "GAS"..
hindi naman po kami nag palit ng engine..
ok naman po kase yung "ENGINE NUMBER" at yung "CHASIS NUMBER"...
Di ko po kase ma rehistro yung sasakyan dahil sa fuel type error..
Yung sasakyan nga po pala ay nabili namin sa Subic last year...
Nung nag punta po kami ng LTO ang sabi po sa akin eh kailangan daw po ipaayos ko dun sa LTO Aparri..
kase dun po naka register ng 2012 yung sasakyan..problema po sa Cavite po ako nakatira..
Ano po ba ang pwede kong gawin para maayos yung mga problema sa rehistro na hindi kinakailangan na pumunta pa ako sa LTO Aparri..
THANKS IN ADVANCE!!
June 5th, 2013 04:00 PM #2
pag may error sa original CR.. sa LTO kung saan ni register aayusin kasi nandon yung papeles mo.. so you have to go to LTO Aparri.. dapat bago nyo binili yan ni check nyo munang mabuti.. or baka makokontak nyo pa yung pinagbilhan and ask them for help..
June 5th, 2013 04:45 PM #4
* _Qwerty_
wala po po bang ibang choices?pero i try ko po kontakin yung pinagbilhan namin..
Thanks po.
June 5th, 2013 04:47 PM #5
* SiRbossR
sir what do you mean na wala pong problem? na i reregister nyo po kahit may error?
June 5th, 2013 05:25 PM #6
Try mo sa ibang LTO magrenew ng rehistro. Yung ibang LTO kasi hindi ganon kahigpit.
June 5th, 2013 06:09 PM #7
June 5th, 2013 06:56 PM #8
MARAMING SALAMAT PO SA INYO..TRY KO PO YUNG MGA SUGGESTION NYO SA AKIN!
GODBLESS PO SA INYO!
- Sep 2008
- 142
June 6th, 2013 10:13 PM #9TS, have a xerox copy of your CR and OR then proceed to the Stradcom office near you, there your papers would be rectified, it would take days though (probably months). But for the meantime just register your car under diesel muna, mahirapan ka lang sa smoke testing na requirement sa lto, kaya hanap ka ng "maluwang" na testing center.
probably safe to buy next yr. two yrs enough time to iron out the kinks. these cars are quite...
VinFast VF 3
