Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Oct 2013
    92 Corolla small body AE92
    Naka HID po kasi yung headlight nung kotse and every 6-7 months nasisira yung ballast which is normal daw pag naka HID
    Im planing to downgrade to a halogen or all weather condition headlight bulb..
    PLS I NEED YOUR ADVICE kung ano pong magandang bulb ang pwede kong ikabit na SANA kasing liwanag ng HID
    Marami pong salamat
    Jul 2006
    Mahal no?
    Tapos dami pa kasalubong mo na nasisilaw ng HID's mo dahil kalat ang buga ng ilaw. Salamat naman at nagpasya ka na bumalik sa stock. Mabuhay ka!
    Marami dyan, Osram Night Breaker (tama ba? .. ), Bosch All Weather, Narva, Hella, etc.
    Google mo.
    Osram night breaker.
    Osram Nightbreaker or Philips Vision Plus/Extreme
    Another option is to have a good electrician upgrade the wirings of your Corolla and and add relays and ceramic sockets (or you can buy a Narva plug and play headlight wiring kit for the Toyota from Banawe), then go for Osram 90W/100W all-weather bulbs + ceramic sockets. This was the set-up on my Corolla AE92 back in my highschool days in the 1990s and it worked well. Make sure also your headlights are clean (you can have it cleaned if its already darkened) and are aimed properly as well. no matter how lakas the headlights are, it wont give the best effect if the headlight aim is not proper.
    osram nightbreaker....
    Oct 2013
    Maraming maraming salamat po sa mga advise nyo.. I think ill go sa osram all weather and upgrade my wiring and sockets,
    But still im open for other opinions baka may mas ok pa bukod sa osram..
    Salamat po ulit godbless
    Oct 2013
    Sir lowslowbenz tama po kayo nakakahiya sa kasalubong at nasisilaw sila and pwede pa akong maging cause ng aksidente
    At mahal paang maintenance kaya po balik na ako sa stock =)
    Jul 2006
    Also bear in mind that even if you're using high wattage bulbs, but your headlight alignment is off, wala rin kwenta yan. Make sure you align your headlights so that it illuminates the road ahead, and not dazzle oncoming traffic.
    Here is a good link for automotive lighting: Daniel Stern Lighting Consultancy and Supply
    Quote Originally Posted by Yujin View Post
    dude, osram nightbreaker ha? it is different from osram all weather. mas maliwanag ang nightbreaker.
    Oct 2013
    Quote Originally Posted by 1D4LV View Post
    Ok po salamat.. Ok din po ang osram nightbreaker pag tag ulan.
92 corolla small body, i wana downgrade my hid Headlights pls i need some advise
